About InfraRed Project
Discussion in 'The Projects Forum' started by ahgan84, Mar 21, 2012.
  1. ahgan84
    Dec 19, 2011
    55
    Hi guys,
    I've been thinking about a project involving a infrared transmission. I've draw out a circuit picture (attachment) for your better understanding of my thinking.
    Can it work? I mean, can the Infrared signal successfully transmitted from outdoor to indoor controller board from a wire/cable?
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    sure it could work, but it might be easier to use a piece of fiberoptic cable from the first transmitter to the last receiver.
  3. ahgan84
    Dec 19, 2011
    55
    You mean the wire I have to use a fiberoptic cable? Is there any fibreoptic cable that can transmit infrared? Could you recommend? Please advice..
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    I mean like this:
    As far as the type of cable, I'm 90% sure that any fiberoptic cable will work (somebody please correct me if I'm wrong) and no, I can't really make a recommendation because I've never had to spec fiber, I was always just given it with instructions.
  5. ahgan84
    Dec 19, 2011
    55
    Does the fibre optic cable need a receiver or transmitter?
  6. strantor
    Oct 3, 2010
    4,302
    1,989
    ?? the light travels through the fiberoptic cable
  7. ahgan84
    Dec 19, 2011
    55
