About Electrical Wire
Discussion in 'The Projects Forum' started by Lightfire, Mar 23, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I am just wondering if the voltage across the wire will be affected if I joined another more electric wire? The common wire that we put electrical wire.
    For example, I has 1 yard of wire and one more 1 yard of wire. Then I am going to connect them together to have 2 yards of wire using electrical wire.
    Now, my question is. If I am going to do that, the voltage of battery will be affected? Which I guess, no.
    Thank you very much.
    Is it okay to use wall outlets even my power supply is 12 volts DC. Just for low voltages purposes only.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
  3. mcgyvr
    Oct 15, 2009
    4,784
    973
    The longer the wire the more voltage drop you will experience.
    And a regular outlet will work just fine for 12VDC BUT is not a good idea in case someone comes along and tried to plug something else into it. So it is highly recommended that you do not use a regular outlet as it is automatically assumed that any electrical connection with a wall outlet will be for 120VAC (or whatever voltage is in your country)
    Lightfire likes this.
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    There is a much more important reason why you should not use a mains type outlet for low voltages.
    If you fit a mains plug to your 12V equipment, you (or someone else) might plug it in to the mains by mistake! :eek:
    The 12V equipment would be wrecked, and there could be a fire. Someone might get an electric shock - which could even kill.
    Please be careful.
  5. Lightfire
    Oct 5, 2010
    690
    21
    What if my wire is 1 kilometer long? :)
    OK, but it is OK to use regular outlet for 12 volts DC? Just need some care?
    Thank you.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    If you look on the internet you will find tables describing ohm's/ft (or meter). Then it becomes a matter of using ohm's law to see if you can use it or not. Wire is very expensive though, so you don't run such lengths casually.
  7. Lightfire
    Oct 5, 2010
    690
    21
    Hey Bill!
    Thanks you came here! P.S. can you answer my question? ;D just one more. :D
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    On this page:
    http://www.powerstream.com/Wire_Size.htm
    is a calculator that will tell you how much voltage you will lose in a wire for a given load, given wire size, given distance, and type of wire (copper or aluminum).
    I strongly recommend against using plugs/receptacles designed for mains power for anything else BUT mains power, and devices that are designed to operate from mains power.
    There are many other types of jacks/plugs that are available for low voltage projects. It is not necessary or desirable to use mains power connectors for anything but mains power.
  9. Lightfire
    Oct 5, 2010
    690
    21
    Why? Is there any problem? :)
  10. djsfantasi
    Apr 11, 2010
    2,899
    870
    Mcgyvr answered these questions in post #3...
  11. Lightfire
    Oct 5, 2010
    690
    21
    Yes. But I asked SgtWookie again just to know what his point why it is not recommended. Maybe their opinions are not the same...
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    For the same reasons as described in post #3.
    Don't use mains connectors for 12v projects. No matter how careful YOU might be, sooner or later someone will plug them into mains power by mistake, and the result could be disastrous/fatal.
  13. Lightfire
    Oct 5, 2010
    690
    21
    But can I use AC designed wall outlet just for testing purposes only? uSING of 12 volts dc battery? :) Because I am afraid of 240 volts. :O: O_O
    P.S. can i put 12 volts halogen lamps on my celing that will be operated by a 12 volts dc battery so if there is apower outages, i can use it. or is it not allowed??? (promise, i will be safety)
    Thank you
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    I had a teacher in my college do that. It was for op amps, ±15V. A power connector seemed perfect, until a student got them confused. He was lucky, the 741 only cratered the protoboard (which at that time was provided by the school). That policy changed soon after.
  15. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    NO!
    Halogen lamps generate a LOT of heat. The lamps would have to be in a lamp holder/socket that is approved for the lamp wattage.
    You would be much better off to use LEDs for low-voltage lighting. Your 50W halogen lamp(s) will drain your battery very rapidly. LEDs can provide a fair amount of light without draining your battery too quickly.
  16. Lightfire
    Oct 5, 2010
    690
    21
    ok. i wont use wall oulet
    ;D
    ;D
    What led is it? the small one? or what? can you give me example???
