i have a dc motor
i need to run it using time.
i mean run for 1 sec then stop.
also i need it at two direction
thanks all
thanks all
ok thanks can u give me circuit for (555 with PWM)???Learn about the 555 chip here: http://www.uoguelph.ca/~antoon/gadgets/555/555.html
PWM is a good way to control the speed of a DC motor.
The voltage and current required by your motor will dictate the switching transistor used. The switching transistor will be controlled by the 555 and the PWM.
Side note: "replay" means "play again;" "Reply" means "say something in response."
by Aaron Carman
by Aaron Carman
by Robert Keim
by Jeff Child
