Providing with only 9V battery, a load such as LED is used... will the current goes as high as 50A++ with power up to 1300W++? Possible? Or i have sumting wrong with it? I am testing my watt meter...
Oh no.... I am using the schematic provided by bhabott:Unfortunately something is wrong with your wattmeter or the way in which you are taking the measurement. Is the meter something you built yourself? Post a circuit or schematic of your measurement setup.
so you mean 9V may have up tp a max of 200ma? yup..that is a watt meter...i juz connected the LED across the load + and -.9V batteries aren't very robust, figure around 200ma max, and then their lifespan is severly limited. My personal experience is they max out at 1A with a dead short (no voltage), and get hot.
Is this circuit you show a wattmeter?
The load you describe, an LED, what limited the current in it? No current limit and the LED is toast.
currently yes....200 ma may be pushing it for a 9V battery, less is better.
You're LED is a dead short without any current limiting. As I said, it is toast. Did you share the 9V between the wattmeter and the load?
