about clock in digital circuit?
Discussion in 'General Electronics Chat' started by Anikets, Aug 31, 2014.
  1. Anikets
    Aug 6, 2014
    11
    what is clock ? why it is necessery ? how to generate it?
  2. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    1/Measures time interval
    2/ Depends what you are doing or timing
    3/ Many ways depending on 1 & 2?
    Max.
    Anikets likes this.
  3. Anikets
    Aug 6, 2014
    11
    i mean to say in digital circuit, how clock is generated?
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    usually with a crystal oscilator and several counters used as deviders. sometimes the o=scilator is seperate from the mcu, and sometimes it is internal. some older home clocks used the line frequency 50 or 60 hz to provide timing for the clock.
  5. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Also R/C oscillator if precise timing period is not required in digital gate logic circuitry.
    Max.
  6. crutschow
    Mar 14, 2008
    13,475
    3,361
    Most complex digital circuits are sequential, where the logic is performed in discrete steps (such as a computer). A timing pulse signal (called a clock) is used to control the operational steps and keep all the circuitry in proper sequence. (An example of a common clocked circuit element is a flip-flip.) This clock is a digital pulse train and normally operates at a constant high frequency, limited only by the operational speed and propagation delay of the various circuit paths. The clock has to allow enough time for all the circuits to settle to their new state before the next clock arrives.
    The clock can be generated by a simple RC relaxation oscillator, or by crystal oscillators if the frequency is critical to maintain an accurate time sequence for the logic outputs.
    absf likes this.
  7. ScottWang
    Aug 23, 2012
    4,925
    777
    >what is clock ?
    A regular high low sequence as square wave.
    >why it is necessary ?
    It is like the heart for human, the heart compressing and pushing the blood, so we have a blood circulation in our whole body, and the same, the clock as the heart to pushing the high low signal to where they should go according to the designation.
    >how to generate it?
    google CD4069 oscillator, ne555 oscillator, crystal oscillator, and to see my blog.
    absf likes this.
  8. MrChips
    Oct 2, 2009
    12,624
    3,451
    There are two classes of digital circuits, combinational and sequential.
    In a combinational circuit, the behaviour of the circuit is determined by input parameters.
    For example, if there are four input parameters a, b, c, d, the output Q of the circuit can be expressed as a function of a, b, c, and d:
    Q = f(a, b, c, d)
    In a sequential circuit, the element of time and the current state of Q must be considered. Hence the next outcome of Q at time n+1 can be expressed as:
    Qn+1 = f(a, b, c, d, Qn)
    Thus the transition from Qn to Qn+1 is dependent on time. That is the purpose of the CLOCK signal. The CLOCK determines when the transition from one state to the next state occurs.
    absf likes this.
  9. Anikets
    Aug 6, 2014
    11
    sir could you please tell me practical example for this?
