about cd 4082
Discussion in 'General Electronics Chat' started by pvpk1971, Mar 3, 2014.
  1. pvpk1971
    Mar 3, 2014
    how much of dc voltage we can we give at input pins?
    can output pin drive a relay?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    It's depend on your supply voltage. Input voltage cannot be higher then your supply voltage.
    Vdd = supply voltage 3V...15V
    No, you need to use additional transistor
  3. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi,
    The CD4082 is specified to work from approx 3V thru 15V, so the input voltage High will be the same as the voltage used to power the CD4082.
    eg: 5V supply means a +5Vmax for a logic high input
    10Vsupply +10Vmax input.
    The CD4082 can only sink and source about 4mA/2mA respectively, so it not suitable for driving a relay coil directly.
    What are you trying to do.?
    E
  4. #12
    Nov 30, 2010
    16,655
    7,294
    Here's the specs on that chip.
    Edit: I must be really slow today!
