About A/D conversion in PIC 16f877
Discussion in 'Embedded Systems and Microcontrollers' started by vijays624, Jan 24, 2007.
  1. vijays624
    Jan 24, 2007
    Hai
    Im doing exp on A/D converter in PIC 16f877, i wrote some code n also did the hardware circuit. But i could not get the result.Can anyone giv me suggestions about how to proceed.I unable to find whether the problem is in hardware r programming.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Post your code and a schematic so we can follow along.
  3. fanie
    Jan 20, 2007
    63
    By default comparators are active, if you do not disable them those pins won't read A/D's. If this isn't the problem do as beenthere suggested.
