About a a Non-OS dac with the shift register
Discussion in 'The Projects Forum' started by gaetan8888, Dec 26, 2008.
  1. gaetan8888
    Thread Starter Active Member
    Nov 14, 2008
    41
    Hello
    Mr Paul Tessier, in this diyaudio thread, show a merge of the digital CS8412 section of a Non-OS dac with the shift register part of the Cambridge DAC3 schematic, without the 7220 oversampling section.
    This are doing some shift registering to give 4x oversampling. I find that this schematic could be quite easy to made.
    http://www.diyaudio.com/forums/showthread.php?postid=1638842#post1638842
    Anybody know if it would work correctly, without the 7220, in a non-oversampling mode, and give the correct timings/shifts and bit clock shifting result ?
    Making a test board, how can we see on a scope, if, in non-os without the 7220, this schematic do give the correct timings/shifts and bit clock shifting result ?
    Thank
    Bye
    Gaetan
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you have an accurate image of the recorded waveform, then comparison should be easy. A DSO would be useful to produce the image file.
