About 8051 u controller.....................!!
Discussion in 'Programmer's Corner' started by RRITESH KAKKAR, Jun 23, 2011.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I want to start u controller for this i want to go for basic like 8051 uc.....
    after searching Google for using it, 8051 kit is needed to burn 8051 program.
    please tell from where to buy 8051 kit online, as i have gone through express kits he was not giving guarantee that this kit will work after courier.
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    In North America the 8051 IC was used about 18 years ago.
    If you want to find one and use it then most information about it is earlier than the internet. Maybe information is still available in your old country.
    WHY DON'T YOU POST ABOUT OLD THINGS IN YOUR OWN COUNTRY???
    RRITESH KAKKAR likes this.
  3. stahta01
    Member
    Jun 9, 2011
    133
    21
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Ok, then i should move to PIC series without going through series like 8051??
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Absolutely! The 8051 is a relic of the past. "Not recommended for new designs."
    PICs are just one of many good choices, though I am biased in favor of them.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I think you all have worked with these basic controller before then PIC, but i am new guy in this..........
  7. stahta01
    Member
    Jun 9, 2011
    133
    21
    If doing a very calculation intensive solution, you might look at the Arm chip sets.
    Note: Arm chips tend to be more of an CPU than an MCU (They tend have less I/O in chip support).
    Tim S.
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    i now i don't want to see more CPU it will be better if i work in this.......8051..or pic
  9. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  10. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Is EEROM has any more futre, and what is max. size of memory in chip??
  11. debjit625
    Apr 17, 2010
    790
    186
    No,when I started it was with PIC (PIC16F84A)...
    I will prefer Microchip's PIC as I use them all the time but, Atmel's products are also good like AT89S52 comes at a price of INR 40.00 very very cheap and for a start with mcu stuff it’s a very good choice as it's based on 8051 architecture.
    Good Luck
  12. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    can you give a link to buy microchip kit with rate, because i don't find it..rate
  13. t06afre
    May 11, 2009
    5,939
    1,222
  14. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have seen that link but, are you sure it is PIC 16series kit, because which i have seen it was different with LCD display on it, and some tact switches ( keypad)....
    This link PIC16xxx seems different...!!
  15. t06afre
    May 11, 2009
    5,939
    1,222
    I am not sure what you are referring to here. The PICKIT 2 and 3 programmer are general programmer/debugger units for Microchip MCUs using flash type program memory. You are not locked to any specific demoboard. If you want you can just get a PICKIT programmer. Hook up any compatible PIC MCU to your bread board. And do what ever you want
    Ps. PIC flash type MCUs always have a F after the series type like 16F628
    mkbutan and RRITESH KAKKAR like this.
  16. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  17. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I found it name it is PIC 16S877A.....
    now please tell.!!
  18. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  19. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The kit seems to be Good, and costly...........!!
    What is Maplab & I2c
  20. t06afre
    May 11, 2009
    5,939
    1,222
