About 8 bit latch by 74373 chip...
Discussion in 'General Electronics Chat' started by RRITESH KAKKAR, Sep 10, 2011.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I am using 74373 to latch AD0 - AD7, but the problem is the enable pin that is pin 11, but when i change it to Vcc and gnd there is no change...,why??
    and i am taking output from Qn...and input to Dn..
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Schematics my friend. Always schematic my friend.....
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    here is my 74373 schematic...
    I am connecting OE to Gnd, the Enable pin is used by ALE(addr. latch enable) of 8085.
    When, i connect it to gnd and vcc, the output remain the same.
    why??
      File size:
      42.2 KB
      60
  4. eblc1388
    Nov 28, 2008
    1,542
    102
    The ENABLE pin enable the latch.
    When the ENABLE pin is HIGH, what happens on the D inputs will be seen on the Q outputs, so the latch is like a wire connecting D input to Q output.
    When the ENABLE pin is LOW, the latch is enabled and the Q outputs retain the logic state prior to the ENABLE pin goes LOW. At this moment, changing the D inputs will cause no effect to the Q outputs.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Pin 1 (output enable) is active low.
    When pin 1 is low, the output is enabled.
    When pin 1 is low, raising pin 11 (latch enable) will cause the Qn output to follow the Dn input. With pin 11 low, Qn will remain in the state it was last when pin 11 was high, unless pin 1 goes high.
    When pin 1 is high, the output is in a high impedance state, and the output won't change with inputs to the latch enable (pin 11) or data.
    With pin 1 high, you should be able to use high-value pull-up resistors to Vcc or GND to change the default (high impedance) logic level if desired.
  6. eblc1388
    Nov 28, 2008
    1,542
    102
    Sqt, either you or I have made a silly mistake about pin#11. :D
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, it was me. :rolleyes:
    I'll blame it on alackacoffee. ;)
    I've edited my prior reply to correct it.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    I also think it would be more correct to use a 74xx374. Tie the pin 1 on the latch low. And then tie the ALE from the 8085 to the clock input (pin 11) on the 74xx374 via a inverter
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, i have to connect this Enable pin (11) to ALE of 8085 as per schematic of 8085..
    what the need of it??
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Because the bus (AD0-AD7) has both address information and data information on the D-inputs. The purpose of ALE(Address Latche Enable) is to capture the low order address information at the beginning of the cycle and hold it for any memory or I/O devices that want to decode this information.
    After ALE goes low the D-inputs become the data and the Q outputs hold the address bits until the next cycle when ALE will go high again and capture a new address. It's all explained in the datasheet and hardware manual.
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Thanks, for the help i got it...
    thanks
  12. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    pics of 8085:-
  13. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Ok, how to choose the bypass capacitor value for quartz crystal of 4Mhz..??
  14. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    help please....
  15. stahta01
    Member
    Jun 9, 2011
    133
    21
    I disagree, no inverter is needed between ALE and 74373
    Note: Everything in this quote is correct; but your conclusion is wrong.
    Edit: I just found the cause of the confusion; an inverter is needed between ALE and 74374; but is not needed between ALE and 74373 chip.
    The ALE is designed so that the Address (AD0-AD7) is supposed to be latched during the trailing/falling edge of the ALE pulse.
    On the raising edge my reference books says the address is still settling; after the ALE going low the address (AD0-AD7) is still valid for almost half a clock cycle.
    And, another site shows the same.
    http://www.8085projects.info/IO-Interfacing-Methods.html
    Tim S.
    RRITESH KAKKAR likes this.
  16. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    yes ......
  17. stahta01
    Member
    Jun 9, 2011
    133
    21
    My 1981 reference book shows no bypass caps; says just hookup an 1 to 6 Mhz crystal and the 8085 divides it by 2 to get its speed. So a 3 Mhz 8085 uses an 6 MHz crystal. Edit: It been decades since I read this book; I bought it brand new.
    ISBN: 0-13-691089-0 Practical Hardware Details for 8080, 8085, Z80 and 6800 Microprocessor Systems by James Coffron
    Google lets you get some results for "Microprocessor 8085 And Its Interfacing" By Mathur
    Tim S.
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    have ever made its hardware..??
  19. thatoneguy
    Feb 19, 2009
    6,357
    718
  20. stahta01
    Member
    Jun 9, 2011
    133
    21
    No, I was thinking of doing the Z80 or 6800 project at the time; never really built them myself. But, the school I was at had an 6800 based board that I did projects with at the time.
    Tim S.
