about 7 segment display
Discussion in 'The Projects Forum' started by vivek.raunak, Jan 19, 2011.
  1. vivek.raunak
    Oct 23, 2010
    29
    plz tell me how pin of 7 segment display is counted.
    plz soon..........
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What's the part number?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The datasheet for the display shows the pins and their numbers.
    The datasheet also tells you many more spec's that you should know.
    Why don't you have the datasheet?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I think our OP is confused about where is pin 1 of the display is.
    Sometimes the corner of the display is slightly flattened at pin 1. Sometimes there is a slight notch at one end.
    Even if you don't have a datasheet available, you can usually figure out which pin does what pretty quickly by using the diode check function on a multimeter, or if you don't have one of those, by using a battery with a resistor and a couple of wires.
  5. Markd77
    Sep 7, 2009
    2,803
    594
    Assuming it's red, yellow or green, I'd recommend 3V and a 470 ohm resistor.
