HomeBody,
Here's a simple reversing circuit for singal phase voltage. I've added simple safety components, overloads, limit switches and such, just a suggestion.
The attached is a "Ladder" diagram and not a wiring diagram. The ladder diagram shows current paths where as the wiring diagram shows how the wiring is actually laid out. Do not confuse the two. In all probability it looks more complicated that it actually is. If needed I can write up a step through of the diagram for you.
Hope this helps,
williamj
Hope this helps,
williamj
