ab biasing
Discussion in 'General Electronics Chat' started by hardrock, Nov 16, 2012.
  1. hardrock
    Nov 16, 2012
    30
    Is it better to run ab biasing
    on a cb amp for am useage???
  2. MrChips
    Oct 2, 2009
    12,642
    3,457
    What the ....?
  3. JoeJester
    Apr 26, 2005
    3,402
    1,227
    Are you talking about an external amplifier to exceed the 5 Watt power limitations?
  4. R!f@@
    Apr 2, 2009
    8,792
    771
    continue...F?
  5. hardrock
    Nov 16, 2012
    30
    Guess , i asked the wrong question.
    every where i read is that class c
    amps want work on am. they are for
    cw or fm. yet the market is full of
    the class c amps. and the majority
    is used on am. i asked a simple
    question. will a class ab sound better
    on am or does it matter. not here 4
    a pissin contest. just a answer. thanks tony
  6. MrChips
    Oct 2, 2009
    12,642
    3,457
    Sorry, couldn't help it. The answer is only as good as the question.
    Ask an obtuse question and get an obtuse answer.
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  8. hardrock
    Nov 16, 2012
    30
  9. vk6zgo
    Jul 21, 2012
    677
    85
    Pretty good guess is that it isn't!
    Many of these amps aimed a "CBers" are not.
    It's not that the people making them are lacking in knowledge--it's more that they don't care!
    On a power meter you may see your 100w or whatever,but a lot of that power is not on your frequency.
    Instead,it is spread over both the CB band,& adjacent bands,due to combinations of your carrier,& multiples of your modulation frequencies mixing to make an unholy mess.
    You will also probably appear at multiples of your channel frequency,on other bands used by other people who won't like it in the least.
    Those folks who pointed out that CB amps are illegal were simply pointing out the truth.
    How good is your antenna?
    The legal output through a better antenna may get you further than 100watts into a lousy one!
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    Since the original post was full of abbreviations, I thought "cb amp" was a "common base amplifier", not a "CB radio transmitter".
    I also thought that "am useage" was "I am using", not an AM radio transmitter.
    Is this how people text on cell phones? Do they know what anybody is talking about?
  11. hardrock
    Nov 16, 2012
    30
    Sorry you didnt understand the abreviations
    that explains why you cant answer the
    question!!!
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    I always SPELL OUT everything so everybody understands.
    But your abbreviations left me guessing.
    I have used and seen many common-base (cb) amplifier transistor circuits but I never had a cb radio.
    When you said, "am useage" then I did not know your were talking about Amplitude Modulation.
  13. MrChips
    Oct 2, 2009
    12,642
    3,457
    We generally know what CB and AM means in the context of radio transmission. But never use abbreviations because not everyone may understand your meaning. Always spell out abbreviations the first time you use them unless the context is obvious.
    In this case your context was not obvious.
