AA batteries getting hot
Discussion in 'The Projects Forum' started by homer2121, Mar 24, 2016.
  1. homer2121
    Jan 2, 2016
    32
    I am a newbie and this may be a silly question but I am making a AA battery holder that holds 4 batteries in a straight line. The entire thing is made of metal and I have soldered springs to each metal divider to hold batteries in place. I have not connected any wires yet bc when i was testing it to make sure they all fit a a couple of the batteries on the one end we're getting quite hot while the other 2 were not. They are brand new out of the package.
    Why are they getting hot is it because I have no wires hooked up yet or am I doing something else wrong?
    Thanks.
  2. DickCappels
    Aug 21, 2008
    2,766
    667
    A photo would help a lot.
    One guess is that the metal springs are shorted together by the metal box
  3. #12
    Nov 30, 2010
    16,671
    7,314
    The outer shell of the batteries is the negative terminal. It's shorting to the frame. Add black tape to the outsides of the batteries.
  4. TheButtonThief
    Feb 26, 2011
    219
    38
    Straight away, I think I'm making a good guess in that your battery holder is shorting the batteries. Insulate it dawg.
  5. homer2121
    Jan 2, 2016
    32
    The battery on the left is still getting hot.
  6. DickCappels
    Aug 21, 2008
    2,766
    667
    If the black stick in the photograph to the right is metal, that's your problem. Use plastic, wood, leather, anything that doesn't conduct to hold your spring contacts.
  7. homer2121
    Jan 2, 2016
    32
    Ok..i thought the contacts of the batteries needed to touch metal on each side to transfer the current..so I need connect them with wire between each battery?
  8. DickCappels
    Aug 21, 2008
    2,766
    667
    As an example, when you wire two or more batteries in series with a load like the light bulb, the electricity travels through both batteries and through the bulb. If you have a conductor connect the + terminal to the - terminal of a battery, you create a short circuit so that the electricity only circulates within that battery, making it hot, instead of doing what you want it to do.
  9. TheButtonThief
    Feb 26, 2011
    219
    38
    Jobe Ha, absf, JohnInTX and 2 others like this.
  10. homer2121
    Jan 2, 2016
    32
    Ok I understand...thanks for the help...one other question...the tube the batteries will slide inside is steel...it is a bit of a tight fit so does it matter if the batteries come into contact with the steel tube inside(not the contacts on the batteries but the body)?
  11. crutschow
    Mar 14, 2008
    13,482
    3,369
    That's okay as long as the insulating sleeve on the battery is not scraped off by the tube.
  12. SLK001
    Nov 29, 2011
    849
    242
    Don't make the steel tube a tight fit to the batteries. If they swell, they will wedge themselves so tight in the tube that they will have to be drilled out to salvage the tube. Take up the side to side slack in the tube with cardboard or paper.
  13. homer2121
    Jan 2, 2016
    32
    Ok thanks
  14. #12
    Nov 30, 2010
    16,671
    7,314
    Been there, done that, stopped the fire before it did much damage.
    Insert a plastic tube that is bigger than the batteries or wrap each battery in black tape.
  15. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    This TS needs to be sternly warned not to mess with the mains.
    They could even hurt themselv'es with "proper" batteries!
  16. #12
    Nov 30, 2010
    16,671
    7,314
    Who said the mains were involved?
  17. ian field
    Oct 27, 2012
    4,447
    791
    Just nipping it in the bud before the TS gets crispy.
    Like I said - this TS could even hurt themselves with "proper" batteries.
