a12v curcuit connected to 24v PSU what will happen?
Discussion in 'General Electronics Chat' started by MarkSimms, Apr 13, 2016.
  1. MarkSimms
    Apr 6, 2016
    42
    if you connect a12v curcuit connected to 24v PSU what will happen? the voltages 12v and 24v could be different, I just want to know what happens ? according to ohms law more voltage less amps , but same resistance, only watts would be the same, it seems like it would work out?
  2. #12
    Nov 30, 2010
    16,704
    7,354
    According to Ohm's Law, double the voltage = double the current.
  3. profbuxton
    Member
    Feb 21, 2014
    233
    68
    Formulate a theory about the result, carry out the experiment, write up the result and let us know your observations.
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    It depends on the circuit.
  5. blocco a spirale
    Jun 18, 2008
    1,461
    370
    It's very easy to find out what happens when you increase the voltage across a fixed resistive load.
    Which version of Ohm's law are you thinking of?
  6. crutschow
    Mar 14, 2008
    13,508
    3,385
    You version of Ohm's law is not the one the rest of us use. :rolleyes:
  7. Willen
    Member
    Nov 13, 2015
    141
    12
    If your load designed to handle 120mA at 12V (1.4 Watts) then the load's resistance is 100 ohms. If you double the supply then law says: 24V/100 ohms = 240mA (5.7 Watts). It's VERY high than needed so the circuits would be fried.
    But it depends on circuit, some circuits have been designed with wide supply input voltage, eg- a circuit regulated by 78xx regulator.
  8. BReeves
    Member
    Nov 24, 2012
    412
    64
    I like this answer...
