A website i made for a school project
Discussion in 'Electronics Resources' started by resicalc, Aug 5, 2016.
  1. resicalc
    Aug 5, 2016
    This is the first time a post something here, its a very nice place for finding usefull things about electronics.
    For a school project i made a website that calculates the value of resistors.
    www.resicalc.com
    I would like your opinion
    Many Thanks,
    Alex
  2. DickCappels
    Aug 21, 2008
    2,758
    667
    Good job. Very cleanly done, and it works!
  3. resicalc
    Aug 5, 2016
    Many thanks, i will try evolve the capabilities of the site ;)
  4. atferrari
    Jan 6, 2004
    2,663
    784
    Why not then, adding calculation of the equivalent of resistors in parallel? Two or more.
  5. wayneh
    Sep 9, 2010
    12,377
    3,231
    It works on my iPhone.
    Are you looking for potential improvement suggestions?
  6. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    Bit of a jump?
    Did you even look at the website?
  7. GopherT
    Nov 23, 2012
    6,303
    4,026
    I think the drop-down should not reset to "None" when Submit is pressed to make the calculation. The selected values should remain on the four drop-downs.
    Also, the text value should be cleared as soon as a user changes a value in a drop down to avoid any confusion. The changed value could be confused with the written value if the written value is not cleared (or immediately updated when a drop-down is changed).
    This doesn't make sense to me, it is not as helpful as if the selected values would remain visible. Note, I use iPad safari - it may remain on other browsers/OS combinations.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    Nice.
    A couple of suggestions.
    After someone calculates a value, leave their choices up there so that they can still see them. This is helpful if they get a result they weren't expecting since they can verify that they entered the values they meant to.
    You need to validate the entered data. For instance, if I select the "Four band" option and enter None-Brown-Black-Brown, I get back "1 OHM, TOLERANCE: 1%". But that is incorrect and almost certainly should have been entered as Brown-Black-Brown-None. So you can check for first band being None (or anything but the last band in the case of a four band and any band in the case of the higher band count) and post an error.
    GopherT likes this.
  9. atferrari
    Jan 6, 2004
    2,663
    784
    Sorry, I do not understand the bit thing.
    I visited the site. Did I miss any option to calculate what I am suggesting?
  10. GopherT
    Nov 23, 2012
    6,303
    4,026
    No, I think Paul was thinking your suggestion was a significant leap from the OP's simple web-tool.
  11. atferrari
    Jan 6, 2004
    2,663
    784
    I see. Gracias Gopher.
  12. samalex
    Oct 9, 2015
    Good work.
  13. Sensacell
    Jun 19, 2012
    1,183
    276
    It's really simple and cute- refreshing change from feature overloaded bloatware.
