A very interesting DEADBUG style
Discussion in 'General Electronics Chat' started by retched, Jul 9, 2010.
  1. retched
    Thread Starter AAC Fanatic!
    Dec 5, 2009
    5,201
    313
    I was quite impressed with the wiring technique used in the following link.
    I like the design idea, but I have to wonder about the antenna effect from the point-to-point wiring of the audio amp.
    Do you think there is anything gained or lost in this design?
    http://www.mhennessy2.f9.co.uk/microamp/construction.htm
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, not trimming the leads would tend to wick heat away (miniature heat sink) but I think the possibility of accidentally bending the leads and creating a short negates the benefit. It needs a proper heat sink.
    I wouldn't worry about RF being picked up; any signal resonant to the wavelength of the resistors' leads would require far more bandwidth than an audio amp could provide.
  3. retched
    Dec 5, 2009
    5,201
    313
    Oh, this was just one photo to whet the appetites and to get folks to check the link..
    The design does include heat sinking and lead clipping.. But a non-ground-plane design for a hi-fi device seems interesting. I suppose the freq. isn't that high, and the designer speaks of 'short signal path' from input to amp to output. The gainclone he talks about has a 1cm signal path.
    Actually, I suppose he does have a ground plane... the whole bottom of the unit is grounded.. so is there a reason to go PCB or not in this case?
  4. sceadwian
    Jun 1, 2009
    499
    37
    Whatever works, it boils down to personal choice. I've always appreciated a good dead bug design, the biggest benefit I can think of is the wire you'll use is almost guaranteed to be of a much higher equivalent gauge than PCB traces. The non trimmed resistors does seem silly. I'd love to seem more pics.
  5. retched
    Dec 5, 2009
    5,201
    313
    Follow the link to see the whole project with many more pics.
