a traffic light(time based)
Discussion in 'Homework Help' started by Gizew, Dec 25, 2007.
  1. Gizew
    Nov 29, 2007
    17
    I have given the assignment to draw conventional ladder diagram for three bulbs which give light alternatively at equal intervals (using time delay contactors)
    the number of timers used must be as minimum as possible.
    my difficulty is on mannaging contactors(time contactors)-please help me.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  4. Gizew
    Nov 29, 2007
    17
    The problem is connecting the contactors. when i try to connect to contactors parallel with their normal closed and openend contacts the lights glow simeltaneously. but what i want is the lamps should give light alternatively in a regular constant time interval.
    in my trial there is a STOP at first place and START next to that parallel to this START there is contact(conventional contact) which is normally oppened. this contact needs enrgization of the contactor that is placed at last parallely to the timers and lamps to be closed. And i have connected the time delayed contactors and lamps in parallel.
  5. agentofdarkness
    Oct 9, 2007
    42
    You can use a timer and a 4 bit counter to simulate a traffic light. The counter has 16 states, 0000 - 1111. You can set up how long you want the red, yellow, and green to be on. If you want red to be on for 4 clock cycles, whenever you have 0000,0001,0010,0011 you want red to be on. So for every counter state (0000-1111) one of the lights will be on. Draw a truth table with the counter states (Q1,Q2,Q3,Q4) and the 3 lights, R, Y, G. Determine which light will be logic 1 for each state. Use K-Maps to derive the flip flop equations.
  6. Gizew
    Nov 29, 2007
    17
    Nice! thankyou!
