A Time Delay Circuit for beginner.
Discussion in 'The Projects Forum' started by Whatashame, Mar 30, 2016.
  1. Whatashame
    Nov 30, 2015
    83
    12
    Here is a fun project for a beginner. The part in photo can be bought for less than 5 bucks, but that's not the point. Only the LED, ( D1) and a diode, (D2), has no information. Just use a 3 volt LED and try small diode. Everything else is on photo. Just use larger parts with same ratings so you can use breadboard first. If you use exact teany tiny parts, connect with liquid (in a tube), instead of hot solder. Hint: I use liquid solder connecting real thin wire with tiny terminals in which I glue together using liquid plastic (lazer lite), as seen on TV), over top of connection. It has not failed yet. That's my secret, or was my secret. Just do one connection at a time not to touch other terminals .Have fun.
  2. Whatashame
    Nov 30, 2015
    83
    12
    By the way, you can use a sound senser, infrared senser, light senser, touch senser or other sensers to make it work. Just install senser between the trigger and V- (GND). That is all that it takes to operate it. If you want to use a remote contoller which works by an infrared LED, that has three wires, connect the 3 wires right at power in, making sure the output wire is connected to the trigger. To be clearer, the 3 wire infrared LED installs this way, positive ( long wire on led) gets put on V+, the middle (shorter wire), gets put on V negitive, the 3rd output wire ( oppisite end of positive wire), connects to the trigger port, terminal n you are done. Try a touch sensor too. It's easy and fun. Use on remote control car. When the delay goes to "0", the car could go backwards.
  3. Willen
    Member
    Nov 13, 2015
    141
    12
    It seems like the world's hardest 555 schematic diagram to understand. :)
    Whatashame likes this.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,298
    Is there a question in there...?
  5. Dodgydave
    Jun 22, 2012
    5,155
    772
    Yes, i think its " can you help me to draw"....
  6. Alec_t
    Sep 17, 2013
    5,977
    1,136
    :confused: I'm not clear why/where the mains-powered table lamp, shown in your schematic, would be mounted on the car.
  7. #12
    Nov 30, 2010
    16,704
    7,352
    What a shame you can't find the Complete Projects Forum instead of having so many people look here to answer your question...which you don't have.
  8. Brevor
    Apr 9, 2011
    282
    56
    Is this post meant for April 1st. ?
  9. Whatashame
    Nov 30, 2015
    83
    12
    I should not have mentioned anything about a car. The drawing ( of the lamp) is to show 1 idea to which this delay could be put to use. Also the purpose of the no/nc and common terminal block. The output side. Good point on your part.
  10. Whatashame
    Nov 30, 2015
    83
    12
    This is a good point. What is easy to one maybe hard for other. Just follow one wire at a time, like a road map. If the photo is inlarged, it is much clearer. This was my first time doing something like this. I am a beginner too. I am what is known as a lay person. I find schematics in that square format , looks simple, but I can't relate to it easily. I don't have that type of vision. That square format is like genius, and I can't figure out who does that, everything's in perfect place and position, but never looks like final result, to me, again, I'm a "lay" person, not a engineer. I thought I give it a whirl. Thanks for input. Much appreciate it.
  11. Whatashame
    Nov 30, 2015
    83
    12
    Love that comment. I knew this would go right over the heads of wonderful , genius types of people that are very knowledgeable of Electronics. Square format Rules, no doubt. But not to us regular folks. I need a map, but that's me. I thought hundreds of "What?" might happen. Beginners don't know any better, like me. Lol
  12. Whatashame
    Nov 30, 2015
    83
    12
    No, that is the best part. Just follow each wire one at a time. All parts are listed except the LED. Must be a 2.7 to 3 volt led. All parts are in position, perfect order. Just start at ,say the top, work down , one wire at a time.
  13. Whatashame
    Nov 30, 2015
    83
    12
    I might make a list exactly what to do. We will see.
  14. Whatashame
    Nov 30, 2015
    83
    12
    Thanks for your input. To answer your concern, it is because I just don't understand how these sites work. I am always doing it wrong. But, I have only one word to say, "What-a-shame" . See?, I messed that up. That is 3 words. Whatashame, whatashame!!!. Lol
  15. Whatashame
    Nov 30, 2015
    83
    12
    Yes there is. The question is, "What is the voltage of the teeny tiny , one and only, LED used as the indicator light, indicating that the delay is working correctly? How was that missed?
  16. Whatashame
    Nov 30, 2015
    83
    12
    That terminal block gets connected to what you want to operate, output. Anything your heart desires, as long it does not exeed ratings of relay, which is , in this case, 10 amps. The lamp is but 1 example. Easy to draw lamp.
  17. Whatashame
    Nov 30, 2015
    83
    12
    Nepal has Mount Everest. AAC site has this "Can I figure this out project"?". Which is harder, climb Everest, or make this device?
  18. Dodgydave
    Jun 22, 2012
    5,155
    772
    For you, i would say making this device...
  19. blocco a spirale
    Jun 18, 2008
    1,461
    370
    No one would have fun trying to make sense of your schematic:(.
    The important thing to take from the preceding comments is that it is essential to take the time to draw schematics clearly using conventional symbols and layout before presenting them to anyone else.
  20. Whatashame
    Nov 30, 2015
    83
    12
