a task with pic16f628 timer 0 . question
Discussion in 'Homework Help' started by Cyrenaica —, Nov 24, 2015.
  1. Cyrenaica —
    Jun 7, 2015
    17
    hi to every1 !!
    i hav a task : make a program on assembler , simulating traffic lights in two directions , with two versions: 1) with software's control timer using TMR0 ; 2) with interrupt of TMR0 .
    the first part of this task is totally completed ( except circuit of algorithm ) and no problem with this , so every switching of lights is controlled fully by timer 0 . okay . but now i am stuck by hours with second part . since it is a quite stupid idea to to force a chip to count digits with counters with BTFSS/BTFSC in macro ( due to power consumption 4 example ) , is there any way to use the first part of task to perform the second part of task ? maybe any other way ?
    interrupt should be whatever me wish , 4 example "by appearing of 0 on PORTA,4 ( by switching ON SA4 ) , start interrupt and make yellow colour blinks for some time then go back to main loop "
    i have tried and its ( maybe ) impossible cause tmr0 controls the changes of lights in the same time ! !
    please , any opinions or ideas are welcomed !
    Code (Text):
    1.     list p=16f628
    2.     #include <p16f628.inc>
    3.     __config _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _LVP_OFF
    4.     cblock    0x22
    5. counter_1
    6. counter_2
    7.     endc
    8. ;================== beginprogram ==================
    9.     org 0x00
    10.     clrf PORTB
    11.     bcf STATUS,RP1
    12.     bsf STATUS,RP0
    13.     movlw b'11000000'
    14.     movwf TRISB
    15.     bcf STATUS,RP0
    16.     banksel OPTION_REG
    17.     movlw b'11010111'
    18.     movwf OPTION_REG       ;prescaler — 1:256
    19.     banksel TMR0
    20.     movlw .0
    21.     movwf TMR0             ;unset tmr
    22.
    23. main_loop
    24.     bsf PORTB,4
    25.     bsf PORTB,1
    26.     bcf PORTB,2
    27.     bcf PORTB,3
    28.     bcf PORTB,0
    29.     movlw .92
    30.     movwf counter_1
    31. loop_1
    32.     call delay
    33.     decfsz counter_1,f
    34.     goto loop_1
    35.     movlw .4
    36.     movwf counter_2
    37. loop_2
    38.     bcf PORTB,4
    39.     movlw .8
    40.     movwf counter_1
    41. loop_3
    42.     call delay
    43.     decfsz counter_1,f
    44.     goto loop_3
    45.     bsf PORTB,4
    46.     movlw .8
    47.     movwf counter_1
    48. loop_4
    49.     call delay
    50.     decfsz counter_1,f
    51.     goto loop_4
    52.     decfsz counter_2,f
    53.     goto loop_2
    54.     bsf PORTB,2
    55.     bsf PORTB,3
    56.     bcf PORTB,4
    57.     movlw .31
    58.     movwf counter_1
    59. loop_5
    60.     call delay
    61.     decfsz counter_1,f
    62.     goto loop_5
    63.     bsf PORTB,0
    64.     bsf PORTB,5
    65.     bcf PORTB,2
    66.     bcf PORTB,3
    67.     bcf PORTB,1
    68.     movlw .92
    69.     movwf counter_1
    70. loop_6
    71.     call delay
    72.     decfsz counter_1,f
    73.     goto loop_6
    74.     movlw .4
    75.     movwf counter_2
    76. loop_7
    77.     bcf PORTB,5
    78.     movlw .8
    79.     movwf counter_1
    80. loop_8
    81.     call delay
    82.     decfsz counter_1,f
    83.     goto loop_8
    84.     bsf PORTB,5
    85.     movlw .8
    86.     movwf counter_1
    87. loop_9
    88.     call delay
    89.     decfsz counter_1,f
    90.     goto loop_9
    91.     decfsz counter_2,f
    92.     goto loop_7
    93.     bsf PORTB,2
    94.     bsf PORTB,3
    95.     bcf PORTB,5
    96.     movlw .31
    97.     movwf counter_1
    98. loop_10
    99.     call delay
    100.     decfsz counter_1,f
    101.     goto loop_10
    102.     goto main_loop
    103. ;********* subroutine *********
    104. delay
    105.     btfss INTCON,T0IF
    106.     goto delay
    107.     bcf INTCON,T0IF
    108.     banksel TMR0
    109.     movlw .0
    110.     movwf TMR0
    111.     return
    112. ;********* subroutineend *********
    113.     end
    114. ;================== end ==================
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    Start by adding a ; to the right of each instruction (or block of instructions) and place a comment - lots of comments, so we know what you intended to do.
    also, if you read the datasheet - you will realize there are two more timers on that chip. An 8-bit and a 16 bit timer in addition to Timer0.
  3. Cyrenaica —
    Jun 7, 2015
    17
    thx for fast answer ! yes i have seen but they need external oscillators afaik , and the task is about tmr0 only . the main circuit in first post doesnt has any external oscs
    Code (Text):
    1. list p=16f628          ;list of options
    2.     #include <p16f628.inc> ; connect an additional output file
    4.                            ; set configuration bits microcontroller
    5.     cblock    0x22           ; determination unit constants
    6. counter_1
    7. counter_2
    8.     endc
    9. ;================== begin of programm ==================
    10. ;********* needed settings *********
    11.     org 0x00               ;make start address 0
    12.     clrf PORTB             ;initialization of PORTB
    13.     bcf STATUS,RP1
    14.     bsf STATUS,RP0         ;choose bank 1
    15.     movlw b'11000000'
    16.     movwf TRISB            ;RB<5:0> now working as OUTPUT
    17.     bcf STATUS,RP0         ;go back to bank 0
    18.     banksel OPTION_REG     ;choose bank of register
    19.     movlw b'11010111'
    20.     movwf OPTION_REG       ;options for timer; prescaler — 1:256
    21.     banksel TMR0           ;choose bank of register
    22.     movlw .0
    23.     movwf TMR0             ;unset timer
    24. ;********* needed setting completed *********
    25. main_loop                  ;this is the main loop
    26.     bsf PORTB,4 ;turn ON green led of one lighter
    27.     bsf PORTB,1 ;also turn ON red led of another lighter
    28.     bcf PORTB,2 ;turn OFF all yellow leds
    29.     bcf PORTB,3
    30.     bcf PORTB,0 ;and turn OFF red led of one lighter (watch the table)
    31.     movlw .92 ;send digit 92 for counter1, to count 0,065ms*92=6 sec approximately
    32.     movwf counter_1
    33. loop_1
    34.     call delay ; goto subroutine
    35.     decfsz counter_1,f ;decrement counter1 (“skip if 0”)
    36.     goto loop_1 ;if counter_1 >0 then go to loop 1
    37.     movlw .4 ;if counter 1=0 then make 4 cycles, totally 8 yellow blinks, every for 8*0,065ms=0,5 sec approximately
    38.     movwf counter_2
    39. loop_2
    40. ...
    41. ...
    42. ...
    43. ...
    44. etc
    45. ...
    46. ...
    47. loop_10
    48.     call delay ;call subroutine
    49.     decfsz counter_1,f ;decrement counter_1 and skip next instruction if it 0
    50.     goto loop_10
    51.     goto main_loop         ;go to the begin of programm
    52. ;********* subroutine*********
    53. delay
    54.     btfss INTCON,T0IF ;check T0IF and skip next instruction if it 1
    55.     goto delay ;t0if=0 - go here
    56.     bcf INTCON,T0IF ;t0if=1 - go here
    57.     banksel TMR0 ;choose bank of register
    58.     movlw .0 ;send a constant (unset tmr)
    59.     movwf TMR0
    60.     return ;return back
    61. ;********* end of subroutine*********
    62.     end
    63. ;================== end of programm ==================
    64.
    i think the table of " switchings " could help to understand completed first part of the task . i have no problem with it , it compiles without any single error and were checked in real pic
    below is the table of switching . programm starts with action 1, then goes to 2,3,4,5,6 etc till 20, then goes back to 1 to repeat the cycle . if table not helps to understand what is going on , i will create circuit of algorithm later
    sorry for broken English
  4. Dodgydave
    Jun 22, 2012
    5,130
    766
    Why do you need 8 sequences of leds, just use the four sequence repeated.
  5. Cyrenaica —
    Jun 7, 2015
    17
    no sir . i must have eight sequences because i have two traffic lights for two perpendicular roads :) it's all ok with my first type of programm
    well . i had re-read datasheet again further and now i think the best idea is to use TMR1 with an internal clock signal ( since we can use (???) programm connection to internal oscillator too , not only external as i thought ) . o_O really there no any other way , to make everything with only one timer as i wished . o_O so , the only thing in my mind now is to put and additional "BTFSS/BTFSC" with "BCF TMRC1S,4" etc , in delay subroutine , which redirects chip for work with other timer :(
  6. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    This is a classic example of a state-machine. Look at your table. Each entry is a self-contained condition, the state of the system. Each line is a different 'state' and the system can only be in one state at a time.
    So.. a way to approach this is to first identify each state that the system can be in. According to your table, the system can be in 1 of 8 states. Code each state like it is a separate little program. Do this by coding 8 different functions (sub-routines), one for each state.
    So now you have 8 different functions. If you called one, it would output the light pattern that you want for that particular state i.e. RED on Main Street, GREEN on the cross street. The next state might be RED on Main Street, YELLOW on the cross street. Then GREEN on Main Street, RED on the cross street.
    That's 3 of the 8 states. The others are similar and describe unique conditions. When you are done, you have 8 subroutines/functions that, when called, set up the lights that define the system's current state.
    Once you have all 8 states coded and working, its time to schedule them by calling them in sequence. Column 2 of your table tells you how to do that:
    call function1;
    delay (for the time in line1, column 2)
    call function2;
    delay(...);
    call function3;
    delay(...);
    ... etc...
    when you get to the end, loop to the starting state.
    To start, I would just use dumb delays. The scheduling will be just the code-flow. There are ways of implementing state machines that are better but I'd do a brute-force approach first. Later, you can add a better scheduler and if you write the light output routines as the self-contained sub-routines as I describe, a better scheduler can use them as is.
    Have fun.
    Cyrenaica — likes this.
  7. Cyrenaica —
    Jun 7, 2015
    17
    thank you , great idea . :) it just makes programm looks neat . i see no difference in functional aspect , but your idea of " how to make program " is a way better to understand if it is being demonstrating to audience :eek:
    recently i have successfully received the highest mark for my homework ! thank to all for opinions and attention ! :) :) :)
    finally , ive used both timer 0 and timer 1 . after simulation in mplab ive have used proteus simulation , and then checked everything in the real pic . below is my code ( maybe itll be useful for some1 ) . comments are deleted . and proteus file i cant attach in forum due to " The uploaded file does not have an allowed extension. "
    Code (Text):
    1.
    2.     list p=16f628
    3.     #include <p16f628.inc>
    4.     __config _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _LVP_OFF
    5.     cblock    0x22
    6. counter_1
    7. counter_2
    8. d1
    9. d2
    10. d3
    11.     endc
    12. ;================== begin of program ==================
    13.     org 0x00
    14.     goto start_loop
    15.     org 0x04
    16.     goto interrupt
    17. start_loop
    18. ;********* list of macroses used *********
    19. delay500us    macro
    20.     movlw D'5'
    21.     movwf d3
    22.     movlw D'5'
    23.     movwf d2
    24.     movlw D'5'
    25.     movwf d1
    26.     decfsz d1
    27.     goto $-1
    28.     decfsz d2
    29.     goto $-5
    30.     decfsz d3
    31.     goto $-9
    32.     endm
    33. ;********* end of list of macroses *********
    34. ;********* needed options *********
    35.     banksel INTCON
    36.     clrf INTCON
    37.     banksel PORTA
    38.     clrf PORTA
    39.     movlw 0x07
    40.     movwf CMCON
    41.     banksel TRISA
    42.     movlw b'00010000'
    43.     movwf TRISA
    44.     banksel PORTB
    45.     clrf PORTB
    46.     banksel TRISB
    47.     movlw b'11000000'
    48.     movwf TRISB
    49.     banksel OPTION_REG
    50.     movlw b'11010111'
    51.     movwf OPTION_REG
    52.     banksel TMR0
    53.     movlw .0
    54.     movwf TMR0
    55. ;********* needed options are done *********
    56. main_loop
    57.     bsf PORTB,4
    58.     bsf PORTB,1
    59.     bcf PORTB,2
    60.     bcf PORTB,3
    61.     bcf PORTB,0
    62.     movlw .92
    63.     movwf counter_1
    64. loop_1
    65.     call delay_1
    66.     decfsz counter_1,f
    67.     goto loop_1
    68.     movlw .4
    69.     movwf counter_2
    70. loop_2
    71.     bcf PORTB,4
    72.     movlw .8
    73.     movwf counter_1
    74. loop_3
    75.     call delay_1
    76.     decfsz counter_1,f
    77.     goto loop_3
    78.     bsf PORTB,4
    79.     movlw .8
    80.     movwf counter_1
    81. loop_4
    82.     call delay_1
    83.     decfsz counter_1,f
    84.     goto loop_4
    85.     decfsz counter_2,f
    86.     goto loop_2
    87.     bsf PORTB,2
    88.     bsf PORTB,3
    89.     bcf PORTB,4
    90.     movlw .31
    91.     movwf counter_1
    92. loop_5
    93.     call delay_1
    94.     decfsz counter_1,f
    95.     goto loop_5
    96.     bsf PORTB,0
    97.     bsf PORTB,5
    98.     bcf PORTB,2
    99.     bcf PORTB,3
    100.     bcf PORTB,1
    101.     movlw .92
    102.     movwf counter_1
    103. loop_6
    104.     call delay_1
    105.     decfsz counter_1,f
    106.     goto loop_6
    107.     movlw .4
    108.     movwf counter_2
    109. loop_7
    110.     bcf PORTB,5
    111.     movlw .8
    112.     movwf counter_1
    113. loop_8
    114.     call delay_1
    115.     decfsz counter_1,f
    116.     goto loop_8
    117.     bsf PORTB,5
    118.     movlw .8
    119.     movwf counter_1
    120. loop_9
    121.     call delay_1
    122.     decfsz counter_1,f
    123.     goto loop_9
    124.     decfsz counter_2,f
    125.     goto loop_7
    126.     bsf PORTB,2
    127.     bsf PORTB,3
    128.     bcf PORTB,5
    129.     movlw .31
    130.     movwf counter_1
    131. loop_10
    132.     call delay_1
    133.     decfsz counter_1,f
    134.     goto loop_10
    135.     goto main_loop
    136. ;********* sub-routinnes *********
    137. delay_1
    138.     btfss PORTA,4
    139.     call timer_1
    140.     btfss INTCON,T0IF
    141.     goto delay_1
    142.     bcf INTCON,T0IF
    143.     banksel TMR0
    144.     movlw .0
    145.     movwf TMR0
    146.     return
    147. delay_2
    148.     btfss INTCON,T0IF
    149.     goto delay_2
    150.     bcf INTCON,T0IF
    151.     banksel TMR0
    152.     movlw .0
    153.     movwf TMR0
    154.     return
    155. timer_1
    156.     banksel PORTA
    157.     bsf INTCON,GIE
    158.     bsf INTCON,PEIE
    159.     banksel PIE1
    160.     bsf PIE1,TMR1IE
    161.     banksel T1CON
    162.     bsf T1CON,0
    163.     bcf T1CON,1
    164.     movlw b'11111110'
    165.     movwf TMR1H
    166.     movwf TMR1L
    167.     delay500us
    168.     nop
    169.     goto main_loop
    170. ;********* sub-routinne of interrupt *********
    171. interrupt
    172.     bcf INTCON,GIE
    173.     banksel T1CON
    174.     bcf T1CON,0
    175.     bcf PIR1,TMR1IF
    176.     bcf PORTB,0
    177.     bcf PORTB,1
    178.     bcf PORTB,4
    179.     bcf PORTB,5
    180.     movlw .8
    181.     movwf counter_2
    182. loop_11
    183.     bsf PORTB,2
    184.     bsf PORTB,3
    185.     movlw .8
    186.     movwf counter_1
    187. loop_12
    188.     call delay_2
    189.     decfsz counter_1,f
    190.     goto loop_12
    191.     bcf PORTB,2
    192.     bcf PORTB,3
    193.     movlw .8
    194.     movwf counter_1
    195. loop_13
    196.     call delay_2
    197.     decfsz counter_1,f
    198.     goto loop_13
    199.     decfsz counter_2,f
    200.     goto loop_11
    201.     retfie
    202. ;********* end of sub-routinne of interrupt *********
    203. ;********* end of sub-routinnes *********
    204.     end                            ;
    205. ;================== end of programm ==================
    /solved o_O
  8. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    Nothing succeeds like success. Well done and congratulations on your high marks!
    If you would like to take the next step and explore ways to make it even better, let us know.
  9. atferrari
    Jan 6, 2004
    2,663
    783
    Hola John,
    Dumb delay. On line delay?
    JohnInTX likes this.
  10. Cyrenaica —
    Jun 7, 2015
    17
    yes , sure ! i am interested in this ! ! please tell me :)
    as i suppose now , we can succesfully complete the task with traffic light by 2 ways: 1) linear algorythm ( like i have done it before , see top picture in pdf-file ) - simple way ; 2) parallel algorythm with modification of " status word " , which choosing which way (route ) the programm will go next time ( see bottom picture in pdf-file ). this way was recommended by my lecturer as alternative , but i have rejected this idea it cause we really havent examined how to do it properly .
    if its possible , then how to improve algorythm further ?
    Mod note: Reduced file size
  11. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    I like what your lecturer has provided in the second page, it is the basis of a finite state machine. The 'status word' is the state indicator. I use them all the time for things like this and PICs are particularly good at them. So... where to start?
    First, a little clean up:
    Instead of explicitly calling out IO in the code flow, do it in subroutines with useful names. Your lights can only have one meaning at a time so have one subroutine per meaning i.e. MainStreetGREEN_CrossStreetRED. The same with any inputs. Rather than asking is PORTA,2 low, ask has the button been pressed? The general rule is to keep your main code as minimal as possible. The code snippet below shows how I would collect the IO initialization and unique light patterns into their own routines. Personally, I put all IO into its own file and INCLUDE "IO.inc". If you look at the resulting code, its easier to read and see what's going on. This idea of separating the program's logic flow from the peripheral actions is important when you get into more complex things, have to relocate pins or - as we shall see - find out that the IO doesn't always behave like it should.
    Code (Microchip Assembler):
    1. ; Breaking out the IO. First, collect all IO - including the initialization - into
    2. ; one place (I would recommend a second file called IO.inc)
    3. ;************** INIT IO  ********************
    4. ; Set up all IO for the system
    5. initIO:
    6.     banksel PORTA
    7.     clrf PORTA
    8.     movlw 0x07
    9.     movwf CMCON
    10.     banksel TRISA
    11.     movlw b'00010000'
    12.     movwf TRISA
    13.     banksel PORTB
    14.     clrf PORTB
    15.     banksel TRISB
    16.     movlw b'11000000'
    17.     movwf TRISB
    18.     return
    19.
    20. ; Each light pattern gets its own subroutine
    21. ;*******************************
    22. MainStreetGREEN_CrossStreetRED:
    23.     bsf PORTB,0
    24.     bsf PORTB,5
    25.     bcf PORTB,2
    26.     bcf PORTB,3
    27.     bcf PORTB,1
    28.     return
    29.
    30.
    31. ;-------------------------
    32. ; Now in main, THIS:
    33. ;***********************************
    34.
    35.     banksel PORTA
    36.     clrf PORTA
    37.     movlw 0x07
    38.     movwf CMCON
    39.     banksel TRISA
    40.     movlw b'00010000'
    41.     movwf TRISA
    42.     banksel PORTB
    43.     clrf PORTB
    44.     banksel TRISB
    45.     movlw b'11000000'
    46.     movwf TRISB
    47.
    48.     banksel OPTION_REG
    49.     movlw b'11010111'
    50.     movwf OPTION_REG
    51.     banksel TMR0
    52.     movlw .0
    53.     movwf TMR0
    54.
    55.
    56. ;becomes THIS:
    57.     call initIO        ; init system IO
    58.
    59.     banksel OPTION_REG
    60.     movlw b'11010111'
    61.     movwf OPTION_REG
    62.     banksel TMR0
    63.     movlw .0
    64.     movwf TMR0
    65.
    66.
    67. ; and THIS:
    68. ;**********************************
    69. loop_5
    70.     call delay_1
    71.     decfsz counter_1,f
    72.     goto loop_5
    73.     bsf PORTB,0
    74.     bsf PORTB,5
    75.     bcf PORTB,2
    76.     bcf PORTB,3
    77.     bcf PORTB,1
    78.
    79. ; becomes THIS
    80. loop_5:
    81.     call delay_1
    83.     goto loop_5
    84.
    85.     call MainStreetGREEN_CrossStreetRED
    86.   ...
    87.
    Things like timer inits should be broken out as well - we'll get to that directly.
    Once we can easily deal with the IO, its time to think about delays. You are using dumb delays that eat up all of the system's resources. Before getting into the state machine, let's fix that.
    We'll use TMR2 to generate periodic interrupts at 10ms intervals. I'll let you give that a try yourself. Select values for the prescaler, PR2 and postscaler to generate interrupts at 10msec intervals. For now, just clear TMR2IF when its interrupted and return to the code. See the datasheet for the 628A to see how to write a basic interrupt code. If you have a scope, pulse a spare output line to confirm you have 10msec. We then will have a system tick that we can use to create other timers. As in the IO, I would put the timer init code in its own routine (initSYSTIK). This code should do everything BUT enabling GIE. Enable GIE as the last thing after ALL inits (IO, Timers and whatever).
    When done with these two things, we will have the tools to move on to a state-driven real time system, one that is applicable to many other tasks.
    Baby steps for now.
    Have fun.
    BTW: Since this is a school project you might not be up for a lot of changes at this time. If that's the case, you don't have to do any of the actual coding, just keep it in mind for the next one :)
    atferrari likes this.
  12. Cyrenaica —
    Jun 7, 2015
    17
    hi guys
    more than year passed
    i should notify that my previous code was wrong
    here is the right one
    Code (Text):
    1. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    2. ; Автор:[DELETED]        ;
    3. ; Дата: 04.12.2015        ;
    4. ; Версія: 1.2        ;
    5. ; Назва: Світлофор автоматичний модифікований                                                        ;
    6. ; Опис: Програма являється імітатором світлофора для сімейства мікроконтроллерів PIC16F62X, викона- ;
    7. ; ним на світлодіодах. Робота регулюється вбудованими таймерами. Світлофор має автоматичне переми-    ;
    8. ; кання, однак вбудована функція ввімкнення жовтих блимань при натисканні на кнопку SA4. Автоматич- ;
    9. ; но повертається до звичайного режиму роботи.                                                        ;
    10. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    11.     list p=16f628                ;список параметрів
    12.     #include <p16f628.inc>        ;підключення вихідного додаткового файлу
    13.     __config _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _LVP_OFF
    14.                                 ;встановлення бітів рекомендованої конфігурації мікроконтролера
    15.     cblock    0x22                ;визначення блоку констант
    16. counter_1                        ;
    17. counter_2                        ;
    18. d1                                ;
    19. d2                                ;
    20. d3                                ;
    21.     endc                        ;блок констант визначений
    22. ;================== початок програми ==================
    23.     org 0x00                    ;встановлення адреси програми
    24.     goto start_loop                ;відсилання до початкового контуру
    25.     org 0x04                    ;встановлення адреси програми
    26.     goto interrupt                ;відсилання до контуру переривання
    27. start_loop                        ;визначення початкового контуру
    28. ;********* список використовуваних макросів *********
    29. delay500us    macro                 ;макрос затримки часу на 500 мкс
    30.     movlw D'5'                    ;
    31.     movwf d3                    ;
    32.     movlw D'5'                    ;
    33.     movwf d2                    ;
    34.     movlw D'5'                    ;
    35.     movwf d1                    ;
    36.     decfsz d1                    ;
    37.     goto $-1                    ;
    38.     decfsz d2                    ;
    39.     goto $-5                    ;
    40.     decfsz d3                    ;
    41.     goto $-9                    ;
    42.     endm                        ;
    43. ;********* кінець списку використовуваних макросів *********
    44. ;********* проведення необхідних налаштувань *********
    45.     banksel INTCON                ;обрано банк регістра
    46.     clrf INTCON                    ;регістр очищено
    47.     banksel PORTA                ;обрано банк регістра
    48.     clrf PORTA                    ;регістр очищено, клямки ініціалізовані
    49.     movlw 0x07                    ;0x07 ---> WREG
    50.     movwf CMCON                    ;WREG ---> CMCON — компаратор вимкнено; порти A є цифровими входами
    51.     banksel TRISA                ;обрано банк регістра
    52.     movlw b'00010000'            ;00010000 ---> WREG
    53.     movwf TRISA                    ;WREG ---> TRISA — четвертий контакт порту A працює на вхід
    54.     banksel PORTB                ;обрано банк регістра
    55.     clrf PORTB                    ;регістр очищено, клямки ініціалізовані
    56.     banksel TRISB                ;обрано банк регістра
    57.     movlw b'11000000'            ;11000000 ---> WREG
    58.     movwf TRISB                    ;WREG ---> TRISB — контакти 0-5 порту B працюють на вихід
    59.     banksel OPTION_REG            ;обрано банк регістра
    60.     movlw b'11010111'            ;11010111 ---> WREG
    61.     movwf OPTION_REG            ;WREG ---> OPTION_REG — переддільник для таймера 0 — 1:256
    62.     banksel TMR0                ;обрано банк регістра
    63.     movlw .0                    ;0 ---> WREG
    64.     movwf TMR0                    ;WREG ---> TMR0 — відлік від 0 до 255 (65536 к. ц.)
    65. ;********* необхідні налаштування закінчені *********
    66. main_loop                        ;визначення головного контуру
    67.     bsf PORTB,4                    ;
    68.     bsf PORTB,1                    ;
    69.     bcf PORTB,2                    ;
    70.     bcf PORTB,3                    ;
    71.     bcf PORTB,0                    ;
    72.     movlw .92                    ;
    73.     movwf counter_1                ;
    74. loop_1                            ;
    75.     call delay_1                ;
    76.     decfsz counter_1,f            ;
    77.     goto loop_1                    ;до цього моменту реалізовувалася подія 1 (дивись таблицю 1)
    78.     movlw .4                    ;кількість циклів ввімкнення/вимкнення зелених світлодіодів: 4
    79.     movwf counter_2                ;
    80. loop_2                            ;
    81.     bcf PORTB,4                    ;
    82.     movlw .8                    ;
    83.     movwf counter_1                ;
    84. loop_3                            ;
    85.     call delay_1                ;
    86.     decfsz counter_1,f            ;
    87.     goto loop_3                    ;
    88.     bsf PORTB,4                    ;
    89.     movlw .8                    ;
    90.     movwf counter_1                ;
    91. loop_4                            ;
    92.     call delay_1                ;
    93.     decfsz counter_1,f            ;
    94.     goto loop_4                    ;
    95.     decfsz counter_2,f            ;
    96.     goto loop_2                    ;до цього моменту реалізовувалися події 2-9
    97.     bsf PORTB,2                    ;
    98.     bsf PORTB,3                    ;
    99.     bcf PORTB,4                    ;
    100.     movlw .31                    ;
    101.     movwf counter_1                ;
    102. loop_5                            ;
    103.     call delay_1                ;
    104.     decfsz counter_1,f            ;
    105.     goto loop_5                    ;до цього моменту реалізовувалася подія 10
    106.     bsf PORTB,0                    ;
    107.     bsf PORTB,5                    ;
    108.     bcf PORTB,2                    ;
    109.     bcf PORTB,3                    ;
    110.     bcf PORTB,1                    ;
    111.     movlw .92                    ;
    112.     movwf counter_1                ;
    113. loop_6                            ;
    114.     call delay_1                ;
    115.     decfsz counter_1,f            ;
    116.     goto loop_6                    ;до цього моменту реалізовувалася подія 11
    117.     movlw .4                    ;кількість циклів ввімкнення/вимкнення зелених світлодіодів: 4
    118.     movwf counter_2                ;
    119. loop_7                            ;
    120.     bcf PORTB,5                    ;
    121.     movlw .8                    ;
    122.     movwf counter_1                ;
    123. loop_8                            ;
    124.     call delay_1                ;
    125.     decfsz counter_1,f            ;
    126.     goto loop_8                    ;
    127.     bsf PORTB,5                    ;
    128.     movlw .8                    ;
    129.     movwf counter_1                ;
    130. loop_9                            ;
    131.     call delay_1                ;
    132.     decfsz counter_1,f            ;
    133.     goto loop_9                    ;
    134.     decfsz counter_2,f            ;
    135.     goto loop_7                    ;до цього моменту реалізовувалися події 12-19
    136.     bsf PORTB,2                    ;
    137.     bsf PORTB,3                    ;
    138.     bcf PORTB,5                    ;
    139.     movlw .31                    ;
    140.     movwf counter_1                ;
    141. loop_10                            ;
    142.     call delay_1                ;
    143.     decfsz counter_1,f            ;
    144.     goto loop_10                ;до цього моменту реалізовувалася подія 20
    145.     goto main_loop                ;відсилання до головного контуру
    146. ;********* підпрограми *********
    147. delay_1                            ;визначення першого контуру затримки
    148.     btfss PORTA,4                ;сигнал на четвертому контакті порту A має високий рівень?
    149.     call timer_1                ;ні — відсилання до контуру таймера 1
    150.     btfss INTCON,T0IF            ;так — перевірка таймера 0 на переповнення. Біт T0IF встановлений?
    151.     goto delay_1                ;ні — відсилання до першого контуру затримки
    152.     bcf INTCON,T0IF                ;так — скидання біту T0IF
    153.     banksel TMR0                ;обрано банк регістра
    154.     movlw .0                    ;0 ---> WREG
    155.     movwf TMR0                    ;WREG ---> TMR0 — таймер 0 обнулено
    156.     return                        ;повернення із підпрограми
    157. delay_2                            ;визначення другого контуру затримки
    158.     btfss INTCON,T0IF            ;біт T0IF встановлений?
    159.     goto delay_2                ;ні — відсилання до другого контуру затримки
    160.     bcf INTCON,T0IF                ;так — скидання біту T0IF
    161.     banksel TMR0                ;обрано банк регістра
    162.     movlw .0                    ;0 ---> WREG
    163.     movwf TMR0                    ;WREG ---> TMR0 — таймер 0 обнулено
    164.     return                        ;повернення із підпрограми
    165. timer_1                            ;визначення контуру таймера 1
    166.     banksel PORTA                ;обрано банк регістра
    167.     bsf INTCON,GIE                ;глобальний дозвіл переривань
    168.     bsf INTCON,PEIE                ;дозвіл переривань від периферійних модулів
    169.     banksel PIE1                ;обрано банк регістра
    170.     bsf PIE1,TMR1IE                ;переривання таймера 1 дозволене
    171.     banksel T1CON                ;обрано банк регістра
    172.     bsf T1CON,0                    ;ввімкнення модуля таймера 1
    173.     bcf T1CON,1                    ;вибір внутрішнього джерела в якості джерела тактового сигналу
    174.     movlw b'11111110'            ;11111110 ---> WREG
    175.     movwf TMR1H                    ;WREG ---> TMR1H
    176.     movwf TMR1L                    ;WREG ---> TMR1L
    177.     delay500us                    ;затримка на 500 мкс
    178.     nop                            ;порожній цикл (для контролю)
    179.     goto main_loop                ;відсилання до головного контуру
    180. ;********* підпрограма обробки перериваннь *********
    181. interrupt                        ;визначення контуру переривання
    182.     bcf INTCON,GIE                ;глобальна заборона переривань
    183.     banksel T1CON                ;обрано банк регістра
    184.     bcf T1CON,0                    ;таймер 1 вимкнений
    185.     bcf PIR1,TMR1IF                ;скидання прапора переривання таймера 1
    186.     bcf PORTB,0                    ;
    187.     bcf PORTB,1                    ;
    188.     bcf PORTB,4                    ;
    189.     bcf PORTB,5                    ;
    190.     movlw .8                    ;кількість циклів ввімкнення/вимкнення жовтих світлодіодів: 8
    191.     movwf counter_2                ;
    192. loop_11                            ;
    193.     bsf PORTB,2                    ;
    194.     bsf PORTB,3                    ;
    195.     movlw .8                    ;
    196.     movwf counter_1                ;
    197. loop_12                            ;
    198.     call delay_2                ;
    199.     decfsz counter_1,f            ;
    200.     goto loop_12                ;
    201.     bcf PORTB,2                    ;
    202.     bcf PORTB,3                    ;
    203.     movlw .8                    ;
    204.     movwf counter_1                ;
    205. loop_13                            ;
    206.     call delay_2                ;
    207.     decfsz counter_1,f            ;
    208.     goto loop_13                ;
    209.     decfsz counter_2,f            ;
    210.     goto loop_11                ;блимання жовтими світлодіодами реалізоване
    211.     retfie                        ;повернення із підпрограми із дозволом переривань
    212. ;********* кінець підпрограми обробки перериваннь *********
    213. ;********* кінець підпрограм *********
    214.     end                            ;
    215. ;================== кінець програми ==================
    there should have been " goto " instead of " return " in some place , i dont remember where
    excuses for late posting
    happy new year everyone
  13. dannyf
    Sep 13, 2015
    2,196
    417
    that would be a perfect project for relay logic / plc.
