A Sudent's Dilemma
Discussion in 'Homework Help' started by Paul Black, Dec 3, 2012.
  1. Paul Black
    Dec 3, 2012
    Hello. I am new to Electronics and need some advice. One of my school projects demands that I rectify and transform 120vac to 90vdc. It is very important that the voltage remain constant and only the current be variable. Any ideas?
  2. #12
    Nov 30, 2010
    16,665
    7,310
    1)Use a transformer to reduce the voltage then use a rectifier to rectify it.
    2)Post school assignments in the Homework Forum.
  3. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Generally that is known as a DC constant voltage power supply, or just a power supply. 90 volts is well above what is typically used but not excessively so.
    When I just Googled "90 volt power supply schematic" I did get several relevant hits. You might also want to try some of the semiconductor manufacturers. I know National Semiconductor ([ulr=www.national.com]www.national.com[/url) (now owned by TI) has an area where you can enter your specs and they will supply a complete design.
    And welcome to the forums!
