A starter kit for a beginner
Discussion in 'The Projects Forum' started by RedOrder, Sep 21, 2012.
  1. RedOrder
    Sep 21, 2012
    Hello to all of you.
    I am in need of some help I would like to hear what starter kit you would recommend for controlling something as simple as some Faller car system for a model railroad.
    What I have is some switches and some relays that I have to controlle.
    So all I need is a simple chip that can handle some simple inputs and then changes the state of some relays.
    I have programmed before lets say more than 10 years ago and lost all my documentation, so I have to start from scratsh.
    Thx in advanced.
    Regards.
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Maybe you could look at the PC based solutions? You can get simple PC software that is easy to setup, which plugs into a relay board, controlled by USB.
    If you don't want a PC as part of the running setup then you will need to take on the more challenging task of learning to program PIC/AVR/Arduino and make it work in hardware.
    RedOrder likes this.
  3. ScottWang
    Aug 23, 2012
    4,933
    777
    If the control rule is fixed, then you can use 8 bits eeprom to input and control output that you needed.
    Input pins → 8 bits EeProm → Datas Output → Transistors Driver → Relay
    You can also use AT89C2051, it's a tweenty pins MCU, easy program and control it.
    Input pins → AT89C2051 → Datas Output → Transistors Driver → Relay
    AT89C2051 datasheet.
    http://www.datasheetcatalog.org/datasheets/270/130451_DS.pdf
  4. RedOrder
    Sep 21, 2012
    Thanks But I would like it to be without an PC to begin with.
    So I was wondering what kind of starter kit there was and that people would recommend.
    Regards
  5. W4GNS
    Member
    Dec 1, 2008
    17
  6. ScottWang
    Aug 23, 2012
    4,933
    777
