A solenoid to press a push button
Discussion in 'The Projects Forum' started by Seosamdot, Jan 16, 2013.
  1. Seosamdot
    Jan 14, 2013
    I need a small solenoid that will, when energized, push down on a pusbutton. The way I want the solenoid to work is to energize, ever time it is pulsed by a dc voltage source. The dc voltage source I'll be using will be anywhere from 6 to 15v. Hope someone can help me. I'll supply further info if requested.
  2. IC-Man
    Jan 3, 2012
    26
  3. gerty
    Aug 30, 2007
    1,154
    304
    Then there's the ever usefull electric car door locking solenoid. There are a couple of different varieties, the moptorized one is the slowest.
  4. Bernard
    Aug 7, 2008
    4,232
    414
    How much force is needed to operate PB & how much travel? For simplicity you need a push type solenoid like an offering on All Electronics, most likley the 24 V model.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Unless the PB has a strong spring, you also need one with a spring return.
    Ken
  6. bocoin
    Jan 24, 2013
    Does the solenoid actually nee to press the button or could the button be replaced by a relay?
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    Or an opto-isolator?
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    A week and no reply.:rolleyes:
    Ken
  9. BillB3857
    Feb 28, 2009
    2,402
    348
    Ya gotta love the single posters! Maybe he found a solenoid that was too strong and punched a hole through his keyboard.
