A small error
Discussion in 'Feedback and Suggestions' started by karthi, Aug 31, 2007.
  1. karthi
    Aug 31, 2007
    To whom in may concern,
    IN all about circuits,
    Volume III - Semiconductors » SOLID-STATE DEVICE THEORY »
    Valence and Crystal structure
    second and third "Na" atom pictures interchanged, please correct this.
    Thank you for providing this excellent online textbook.
    Long live internet and Altruistic people.
  2. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    image 03398.png has been fixed at ibiblio
    Thanks for the correction, karthi
  3. karthi
    Aug 31, 2007
    Not corrected Still.
    Please correct this error.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I believe the reason that the error has not been fixed in the AAC forum is that they lag corrections in the ibiblio.org site as it requires the updated version to be transferred from ibiblio.org to the forum which takes several days.
    hgmjr
  5. jrap
    Administrator
    Jun 25, 2006
    967
    202
    updated now :)
    thanks karthi and Dennis!
  6. Unregistered
    Guest
  7. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    The reason this is not an error is that this set of volumes uses "electron flow " instead of "conventional current flow". It is the right handed rule if you point your thumb in the direction of current flowing out of the (+) battery terminal through the wire to the (-) battery terminal. It is the left handed rule if you poit your thumb in the direction of electrons flowing out the (-) terminal of the battery through the wire back to the (+) terminal.
