A simple question
BershaM
Joined Aug 22, 2011
17
Can rectification from ac to dc be done without diodes?
some told me it can be done with capacitors but i don't understand how
thanks in advance
Papabravo
Joined Feb 24, 2006
21,227
In the absence of a schematic I find the claim of rectification with capacitors to be dubious. The essence of rectification is blocking the flow of current in one direction, while letting it pass in the other direction. AFAIK a capacitor cannot do that.
You could do it with a 2-element vacuum tube, which we used to call a diode before the semiconductor variety was invented.
Why would you want to do this? Diodes are so cheap as to be virtually free.
Wendy
Joined Mar 24, 2008
23,429
No, but there are many ways to make a rectifier, usually involving dissimilar materials. Selenium and Copper layered for example. A Schottky diode doesn't have a classic PN junction.
I read PB post after posting this, vacuum tube diodes are also a good way to go about it.
vpoko
Joined Jan 5, 2012
267
If there was a DC offset in your signal (for example, a sine wave oscillating between 3V and 5V) you could use a capacitor to "bleed off" the AC and leave you with just the DC component (4V in this case), but that's probably not what you have in mind (and certainly wouldn't be considered rectification).
BillB3857
Joined Feb 28, 2009
2,571
