A Simple Diode Problem
Discussion in 'Homework Help' started by Abhinavrajan, Aug 7, 2016.
  1. Abhinavrajan
    Aug 7, 2016
    77
    I have a very simple Diode problem.
    I am unable to solve the problem as I am missing to see
    something very obvious/simple.
    Please help me on how to arrive at the solution and let me know how to approach.
    I have attached the image of the problem.
    Thanks in Advance.
      File size:
      308 KB
      23
  2. crutschow
    Mar 14, 2008
    13,505
    3,376
    You need to determine at what point in time the diode becomes forward biased.
  3. Alec_t
    Sep 17, 2013
    5,977
    1,136
    If you are not sure what an 'ideal diode' is, look it up.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Under what conditions is the diode forward biased?
    What voltage does the ramped supply need to output in order for those conditions to be met?
    At what time does the ramped supply output that voltage?
    Now YOU need to show YOUR best attempt to work YOUR homework problem.
  5. dannyf
    Sep 13, 2015
    2,196
    417
    Once Vs is greater than VB, it starts to conduct.
    Done.
