a question regarding this article
Discussion in 'Homework Help' started by transgalactic, May 17, 2008.
  1. transgalactic
    Thread Starter Active Member
    Apr 29, 2008
    74
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What voltage source are you referring to?
    hgmjr
  3. transgalactic
    Apr 29, 2008
    74
    the voltage source of the minimised
    Thevenin circuit
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    If you temporarily remove the 2 Ohm resistor from the circuit, you will end up with a total voltage across R1 and R3 of 21 volts (28V - 7V). The total resistance in the loop is 5 ohms. Ohm's Law permits you to calculate the current in the loop by dividing 21 by 5. The current is 4.2 Amps. Next, mulitply 4 Ohms times 4.2 Amps and you get 16.8 volts dropped across R1. Subtract 16.8 Volts from 28 Volts and you get 11.2 Volts. This is where the 11.2 volts comes from.
    hgmjr
  5. transgalactic
    Apr 29, 2008
    74
    thanks i think igot think
    ill try to apply it to other questions
