a question regarding NODE equation..
Discussion in 'Homework Help' started by transgalactic, May 18, 2008.
  1. transgalactic
    Thread Starter Active Member
    Apr 29, 2008
    74
    http://img185.imageshack.us/my.php?image=img8857hj0.jpg
    i watched an MIT lecture
    and he presents there an example
    in which he constructs node e2 equation in a very weird way
    some how he decides the directions of the current
    i dont know how
    i think i understand the system of how he does the
    he takes out e2 and subtracts by the voltage from the line
    and divides by it resistor
    but why the I1 is negative
    i dont know why he does this equation like this
    and not the normal KCL method
  2. AlexK
    May 23, 2007
    34
    I think it's easiest to see if you transfer I1 to the other side of the equation,
    and then regard I1 as the current going INTO the node e2 and all the other as going out. And according to KCL they must be equal.
    So, I1 goes in and equals: IR4+IR5+IR3 which all go out (as was indicated in the picture)
    Hope that helps.
  3. transgalactic
    Apr 29, 2008
    74
    but there is not I variables
    if KCL we suppose to have each current represented by I
    how did he substitute that?
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    There actually are current terms contained in the expression. Don't forget ohms law states that current = volts divided by ohms. There are several terms that are volts divided by ohms. Each of these V/R terms has the units of Amps.
    hgmjr
  5. transgalactic
    Apr 29, 2008
    74
    i cant understand the reason why he subtracts e2-V0??
    its always e2 - (the other voltage)
    why is that??
