A question regarding a.c.
Discussion in 'General Electronics Chat' started by yousuf, Mar 19, 2012.
  1. yousuf
    Mar 21, 2009
    11
    Hi everyone,
    I have a query in my mind that what will happen when frequency of main voltage(220 V ac) increases from 50 to 60(or more) accidentally.What will be effect on output voltage(and frequency) from a step-down transformer connected next to main supply cable for power supply circuit???
    Plz plz answer my question
  2. crutschow
    Mar 14, 2008
    13,492
    3,372
    The output voltage of a power transformer will not change significantly with frequency. The output frequency obviously will, since the input and output frequencies are always the same.
  3. vpoko
    Member
    Jan 5, 2012
    258
    47
    Is mains frequency accidentally changing a common problem? I wouldn't think that should ever happen.
  4. #12
    Nov 30, 2010
    16,684
    7,322
    Mains frequency is so stable that (in most countries) it can be used as a time reference for clocks over periods of months to years.
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    If a British power supply was accidentally plugged into a US outlet it would see just a shift in frequency.
    Practically, very little change would be noted. The disaster scenario for a transformer is when it "saturates," meaning the magnetic field of the core has reached it's maximum. Running it at a higher frequency, thus reversing the field sooner is actually somewhat better to avoid this situation.
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Many power supplies say that they are rated for 50/60 hertz on the case. A shift of 10 hertz probably won't cause harm to the device, especially if it says it's rated for both frequencies. If not, it wouldn't be the worst thing to do to the supply, but it's not really the best either. If it's just a basic transformer power supply, the output frequency should be fairly close to the input frequency, but the voltage shouldn't change much.
  7. P-MONKE
    Member
    Mar 14, 2012
    83
    5
    Just as an aside to this, I am currently restoring a 1974 Midway 'Chopper' arcade game. This was manufactured in America and I am in the UK.
    A step-down transformer allows the electronics to work fine and dandy.* However, all of the sound effects (bar one) are created using an eight-track tape player which, you've guessed it, runs on an AC motor directly off of the PSU. The 17% speed reduction is most definitely noticeable on the vocal samples! :eek:
    I think maybe a custom pulley and new drive belt may be on my 'to do' list.
    *Once I've fixed all of the faults!
    DerStrom8 likes this.
  8. #12
    Nov 30, 2010
    16,684
    7,322
    One last shot...when I was designing linear power supplies
    (They're called antiques now.)
    The only difference between a 60 Hz model and a 50 Hz model was that the mains transformer had 6/5 times as much iron in the core for 50Hz countries.
    The slower power wave required more iron to keep the core from saturating magnetically.
    That's all.
  9. P-MONKE
    Member
    Mar 14, 2012
    83
    5
    Would this possibly cause long-term reliability issues with a 60Hz transformer being run at 50Hz? Or are they over engineered enough for it not to really matter?
    Sorry if I'm thread-jacking a little, but it seems relevant here.
  10. #12
    Nov 30, 2010
    16,684
    7,322
    Yes. A mains transformer designed for 60 Hz can have saturation problems at 50 Hz.
    It usually WILL have problems because the almighty dollar dictates that engineers design the absolute minimum quality into their parts. That means that 20% extra iron is not likely to be inside your 60Hz transformer.
  11. P-MONKE
    Member
    Mar 14, 2012
    83
    5
    Thanks for that #12 - I'll have to advise the owner about the likelihood of even more expenditure! lol.
  12. yousuf
    Mar 21, 2009
    11
    Actually,the purpose of my question is that how frequency will effect the current and voltage???? I know that step-down transformer have some mechanism of maintaining voltage(a/c to rated value of transformer),but how varying frequency will effect the two parameters(current and voltage)?
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    Ideally, not at all.
    Transformers are tweaked for best efficiency at a specific frequency, so it could have some affect it a bit.
    Voltage and frequency are separate parameters. They can interact, but only on a case by case basis.
    Voltage, current, and resistance are all part of Ohm's Law. You don't see frequency in there anywhere.
  14. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Unless, of course, you bring in impedance to the circuit, but even then, it's only the voltages and currents through the load that change. Is that what you were asking, yousuf?
  15. yousuf
    Mar 21, 2009
    11
    No,actually I'm interested in knowing effect of frequency on current and voltage. And after Bill's post I got some clarification now..
  16. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Ok. I just mentioned that because, for example, if you connect an inductor and a resistor to the output of the transformer, the frequency output will change the voltage and current through the inductor. Glad you're getting some clarification, though :)
