There is no shifting of current in the circuit theory model, but each time I try to see what happens in any physical arrangement of conductors, I see current sharing. I'm not saying I am analysing it in enough detail to determine how much current flows, but I see mechanisms that cause currents to flow in the second inductor that are not predicted by the circuit theory model.Ah, I think I misinterpretted your post and thought you were saying that a zero resistance inductor would always have zero voltage across it because the resistance is zero.
But I see what you are getting at and, yes, there would be no shifting of current. But this is not the big quandry that it might seem. Consider a tank of water sitting on a table and we sit a second, empty tank next to it and then insert a tube the comes up out of one tank, goes over the rim, and down into the other tank. The total gravitational energy stored is more than if the two tanks had the same water level and there is even a path for water to travel. But if the tube wasn't filled with water when it was inserted, then there is an "activation" energy that must be overcome in order for an equilibration to happen. Without that impetus, the system will be happy sitting there with more than minimum energy.
