a question on norton method..
Discussion in 'Homework Help' started by transgalactic, May 15, 2008.
  1. transgalactic
    Thread Starter Active Member
    Apr 29, 2008
    74
    http://img391.imageshack.us/my.php?image=img8855ew6.jpg
    why "I" is negative??
    i know that KCL says that the sum of the currents that goes in
    equals the sum of the currents that goes out
    here i dont know what current goes into the node
    and what current goes out??
    i dont know how you decided the direction of each current
    i am new to this stuff
    and i think that the "I" current is pointed up
    so it goes into the node
    the second current the goes threw "R1" also come into the node
    because the currect goes from the plus of the battery to minus of the battery
    where did i go wrong??
    i cant see the conventions here
    i cant see how the currents flow using these conventions
    in what case we have e-v and in what v-e
  2. Caveman
    Apr 15, 2008
    471
    You pick the direction of the currents. If you pick backwards from actual current flow, the answer will come out negative. It will be correct.
    In this case, you are saying that all of the currents are going out. Since none are going in (because you said), the other side is 0.
    \frac{e - V}{R_{1} is the current going out through R1.
    \frac{e}{R_{1} is the current going out through R2.
    And since you are talking about currents going out, you must use -I
    You could just put it on the other side of the equation and it would be positive. But through simple algebra you can see that they are the same.
  3. Caveman
    Apr 15, 2008
    471
  4. transgalactic
    Apr 29, 2008
    74
    but this is normal KVL equation
    why it called the norton method???
  5. Caveman
    Apr 15, 2008
    471
    It is not called the norton method. That was my point. And it doesn't really use KVL. It primarily uses KCL at the various nodes to provide a methodical process for solving these kinds of circuits.
  6. transgalactic
    Apr 29, 2008
    74
    this example is for using norton method on a circuit
    where does the norton stuff come out??
  7. JoeJester
    Apr 26, 2005
    3,393
    1,211
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The premise of Norton Theorem is that you can reduce (simplify) a linear circuit to a single current source and parallel resistance (the Norton Equivalent Circuit) driving a load.
    See: http://www.allaboutcircuits.com/vol_1/chpt_10/9.html
    Also see the related Thevenin Theorem: http://www.allaboutcircuits.com/vol_1/chpt_10/8.html
    And finally the Norton-Thevenin Equivalences: http://www.allaboutcircuits.com/vol_1/chpt_10/10.html
    Dave
