MaxHeadRoom
- Joined Jul 18, 2013
- 28,698
Although in the true radio switch it can be random selectable.Yep. That's about what I was looking for. Thanks!
Max.
Yeah, I thought about that, too. But that would involve either (a) a complicated system of relays or (b) a microcontroller. Neither of which appeal to me (at this moment, anyway).Although in the true radio switch it can be random selectable.
Max.
A quad RS flip flop should make a one chip solution.Yeah, I thought about that, too. But that would involve either (a) a complicated system of relays or (b) a microcontroller. Neither of which appeal to me (at this moment, anyway).
Any particular IC I should look at?A quad RS flip flop should make a one chip solution.
It wouldn't get too complex with only four switches and diode logic.
Pull up/down resistor on each R and S. As per type.
One momentary switch to each S. (to set Q)
3 diodes from each switch to the"not wanted" R (resets). (to reset others)
Outputs from Q1 thru Q4.
Cool. Thanks!CD4043 or CD4044 depending on high or low outputs needed.
http://www.intersil.com/content/dam/Intersil/documents/cd40/cd4043bms-44bms.pdf
I followed most of it. I'm still a bit of a rookie, but I got the general idea. Draw it up and lets take a look. Thanks for helping me out!Did you follow my description.
If someone agrees that it might work, I could draw it up.
Here's my first try.I followed most of it. I'm still a bit of a rookie, but I got the general idea. Draw it up and lets take a look. Thanks for helping me out!
Ahh, now I see what you were talking about regarding diodes. That makes perfect sense. Are the resistor values critical? Or can I use the same arbitrary value on all pins?Here's my first try.
Ignore "NOT Q" It's not available in the 4043.
Selected outputs go high.
Use 4044 if you want low.
Another good idea. Is the "common" pin connected to anything? Ground? Or left floating?The diodes and drivers can be dip arrays also.
Like a 50V 500 mA darlington driver array.
http://www.toshiba.com/taec/components2/Datasheet_Sync/200910/DST_TD62083APG-TDE_EN_11446.pdf
Although, using only 4, the board layout would be easier using discrete.
I'm not an fet guy.
But I'm sure Max could show you the interface.
I haven't done a cmos project in years, but the regulation, bypassing, and pull up/down rules should pretty forgiving in a static switch app.
Thanks again, inwo. I'm going to think about these options over the next couple of weeks and then put 'em all to the breadboard. I'll make sure to check back in and give a report.The driver was just an example.
One should be chosen based on your requirements of voltage and current.
Data sheet shows the 62084 a better choice for cmos over 5volts.
The 62083 is just one that I had a bunch of.
Along with:
62783
62003
62064
62004
The common is connected to the +supply, that supply the relays. It has the clamp diodes built in that would normally need to be connected across relay coil.
The pull down resistors value isn't important. IMO
Most switches like a fairly high value of current. I would go with something around 47K. I can't think of a reason why anything from 1K to 500K wouldn't work.
Diodes can be small signal type.
By the way I haven't built this. Nor have I looked for availability of parts.
I certainly wouldn't commit to this before bread-boarding or getting other opinions.
It's easy for me to get high/low logic mixed up.
It looks to me like a high to set=high to Q=low to the open collector drivers=relay pull in.
Another thing of course is power reset condition.
I'm assuming that on "power up" all Qs will be in the reset=low condition=relays off.
I haven't actually looked.
