A Question About DPDT Switches for Open Circuits
Discussion in 'The Projects Forum' started by Njb7, Aug 10, 2011.
  1. Njb7
    Aug 10, 2011
    Do they make automatic DPDT switches that will switch on a timer to swap ground electrodes continuously?
    This is actually for a high voltage application as well. 30 kV at the voltage supply.
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    I think you need to elaborate a lot more on the application. You want a DPDT switch to reverse the polarity a 30KV source?
    Ken
  3. ErnieM
    Apr 24, 2011
    7,436
    1,625
    You can get a DPDT relay to do the reversing.
    Getting a relay to work at those voltages is the trick.
