a question about Bragg's experiment
Discussion in 'Physics' started by logicman112, Oct 19, 2010.
  1. logicman112
    Thread Starter Active Member
    Dec 27, 2008
    69
    2*d sin(teta) = n * lambda
    This is the formula of Bragg. How can we measure 'n'?
    An important fact which no physic book wants to talk about!!
    'n' is the order of the reflected beam, what does it mean? How we can measure it?
  2. R!f@@
    Apr 2, 2009
    8,790
    771
    If none of 'em talks how did u know abt it?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Do you mean this?
    Bragg's Law
    Curses! Beenthere and moved on!
  5. logicman112
    Dec 27, 2008
    69
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Your mistake is the expectation that there is a single solution -- there isn't. The statement that "n is an integer" just means that there may be multiple solutions depending on the wavelength of the light and the geometry of the crystal lattice. Why are you being so obstreperous anyway?
  7. DeminJanu
    Oct 26, 2010
    as stated above, there are many solutions.
    every time 2*d*sin(theta) equals an integer multiple of the wavelength, you see a bright spot. ie. you see a whole set of bright spots, equally spaced apart.
    similar to this:
    http://en.wikipedia.org/wiki/File:Single_slit_and_double_slit2.jpg
    (slightly different math, but same idea of coherent interference from regularly spaced sources/reflection)
  8. logicman112
    Dec 27, 2008
    69
    I thought Bragg's experiment can measure the wavelength. So it can not!!
    Because there are two variables unknown, n and the wavelength!!
    So why the following extract from a famous physic book states that William Bragg invented this theory to measure wavelength?
    In 1913, William Bragg and his son Lawrence, proposed a simple method of
    measuring the wavelengths of X-rays by means of their ‘reflection’ from crystal planes.
    Crystals comprise atoms (or ions) that are arranged in a spatial lattice, such that they....
  9. logicman112
    Dec 27, 2008
    69
    Please add your comments then I will let you know something which has never been mentioned in physic books. How 'n' can be measured in Bragg's experiment logically?
  10. Markd77
    Sep 7, 2009
    2,803
    594
    Am I missing something? I'd have thought you increase the angle from zero until you see a patch of X-rays. That means n=1. The next patch is n=2, etc.
    I imagine you see X-rays at angle = 0 because they go through the sample - ignore that.
    logicman112 likes this.
  11. logicman112
    Dec 27, 2008
    69
    Mark, you are right.
    We see the first bright spot in the minimum path difference and the minimum path difference happens when n=1.
