A project for Digital Logic
Discussion in 'The Projects Forum' started by PraveshKoirala, Jan 25, 2012.
  1. PraveshKoirala
    Jan 25, 2012
    5
    Hello everyone!! I'm new to this forum and this is my first post. So I beg your pardon for any wrong I may commit.
    Now as for my problem. My Digital Logic teacher just finished our Combinational logic section. And he has given us an assignment. We are required to build a project using our new-found knowledge (using basic gates only). So my problem is, I've never done these sort of project before and I'm confused as to what to make (we are only required to provide the schematics). So, it would be a great help if you guys could suggest me some small projects.
    Thanks!
  2. JDT
    Feb 12, 2009
    658
    85
    Here is an idea:-
    7 LEDs arranged like the face of a dice. 3 on each side, 1 in the middle.
    So there is 6 possible states: 1 - 6. Some of the LEDs can be connected together.
    Draw the logic circuit that can drive these LEDs and cycle through the 6 states in order when an input is clocked.
    You will need to use basic gates plus 3 flip-flops (which can be made from basic gates). Why 3?
    Too difficult? Start with a truth table for the 7 LEDs. Example: the center LED lights on states 1, 3 and 5 only.
    Then a State Diagram. Then combinational logic. Finally the circuit.
  3. BSomer
    Member
    Dec 28, 2011
    433
    106
    The most often project example used when I was in college was digital clocks using seven segment displays and shift registers. Granted these are using more than just basic gates. I made a circuit with a keypad to be used with a electric lock. Enter the right code and the lock opens. You can do this with basic gates and a few buttons. Something you can do is look around your house and look at things that you think could be automated or electronically controlled. Then, as JDT stated, start with a truth table and move on from there.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    You could code an algorithmic procedure, such as making breakfast, using a Finite State Machine. In a VERY abstract level, though.
