A power transformer design technique
Discussion in 'Electronics Resources' started by EDOKUS, Jul 5, 2010.
  1. EDOKUS
    Feb 28, 2010
    I'd like to submit a transformer design technique that I've used over the years as an electronics engineer. The design process determines the E I lamination size, number of primary and secondary turns, wire size, turns per layer, coil build, coil fit, and magnetizing current.
    Ed Dokus
    <snip>
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Please read the rules of the Completed Projects forum.
    This project has sat in limbo basically because it didn't meet the above requirements. If you want to resubmit this entry please rework the entry to meet the requirements, then drop one of the moderators a PM pointing to it. If it is acceptable a moderator can move it back to the Completed Projects forum and clean up notices and suggestions (making them invisible).
    While an interesting document, this does not qualify as a project.
  3. Jotto
    Member
    Apr 1, 2011
    159
    17
    But some excellent information.
  4. debjit625
    Apr 17, 2010
    790
    186
    Its not a project but definitely a very good document for transformer design...
