A portable light therapy device.
Discussion in 'The Projects Forum' started by Benny D, Nov 5, 2015.
  1. Benny D
    Nov 5, 2015
    Mod edit:
    Please don't reply to a old thread close to 5 years ago.
    Now you have your own.
    This thread was split from -- Building a 'SAD' Light Therapy box.
    I have recently built a portable light therapy device to help with my Seasonal Affective Disorder. One thing I learnt was that wavelength is important. Blue and greens (450nm - 550nm) are good for treating SAD, but just using white light without knowing how much blue/green is in there is a big no no. Using blue or green LED's with an output of about 300 lux (measured at the eye, not the light source!) is the way to go.
    A couple of good references here:
    https://www.flinders.edu.au/sabs/psychology/research/labs/sleep/bas.cfm
    https://re-timer.com/blog/2015/04/17/green-red-white-or-blue-light-therapy/
  2. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Pretty sure Elektor magazines published a project a couple of years ago.
    AFAICR: it was pretty much a panel of bog standard blue LEDs.
  3. recklessrog
    Member
    May 23, 2013
    346
    102
    There was one that I saw on sale in France. It contained 4 Phillips "North light" bulbs as used by artists etc, these have a specific spectrum that matches the light from the northern sky. The diffuser looked like a sheet of frosted glass.
    I built a U.V box for exposing photo etch pcb's, I used a piece of the plastic that sits in front of the flourescent tube or led's in lcd tv's as the diffuser with only a piece of 4mm clear glass on top. This attenuated the U.V less than frosted glass. So use thicker frosted, (acid etched) glass if u want to block the U.V.
  4. ian field
    Oct 27, 2012
    4,447
    791
    I'd shy away from any kind of discharge tubes - even sunbed tubes require filter goggle eye protection.
    You can now get UV LEDs - and they come with an eye safety warning!
  5. recklessrog
    Member
    May 23, 2013
    346
    102
    The SAD light box's sold by Maplins and other sources use a special fluorescent tube that they sell separately as a spare.
  6. ian field
    Oct 27, 2012
    4,447
    791
    Quite often; things sold by Maplin are not fit for purpose.
  7. recklessrog
    Member
    May 23, 2013
    346
    102
    Their sad lights seem to be the same as a lot of other suppliers, reviews are mixed, with about 50/50 as to whether they actually do any good. Probably do better to take a short winter holiday to somewhere sunny!
  8. ScottWang
    Aug 23, 2012
    4,924
    776
    I'm not sure why, but you shows that as a newbie to replied to a old thread?
