Throughout my experience in electronics i found out a good, cheap, and easy way to apply a silkscreen on a PCB.
-Materials:
-Procedure:
Before you start you must have your board etched and drilled with no chemicals on it so it wont react with the acetone.
The first thing you have to do is to align your PCB drills with the silk screen you can use a needle, the most important thing is that you must align the right component symbol with it drills. Make sure that the printed side facing downward on the PCB.
Then put Acetone on the paper, the plane side facing you, then press on the paper until the acetone evaporates, dont use much acetone, and make sure that the hole diagram is covered with acetone.
When there is no more Acetone, peal of the paper and soak it in water and remove every bits of paper.
Finally spray the side with clear body spay so it will last longer, most body sprays are heat resistant so dont wory, you can solder safely.
I know, you can just use toner transfer, but this works better for me than getting the toner pealed of easily, i find that stronger and cheaper.
Thank you for reading..........
-Materials:
- A photocopy image of your inverted silkscreen.
- Acetone, nail polish remover will be better.
- Car body clear coat spray, or any similar (optional).
- PCB.
-Procedure:
