A new technology for air conditioning
Discussion in 'Physics' started by cmartinez, Jul 21, 2016.
  1. cmartinez
    Thread Starter AAC Fanatic!
    Jan 17, 2007
    3,698
    2,790
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Great new inventions, but about 90 years too late: https://en.wikipedia.org/wiki/Einstein_refrigerator
    Edit: Oops, didn't read the whole article. I still wonder whether the desiccant can keep pace with way more than 2 liters per hour of water produced.
    John
    cmartinez likes this.
  3. cmartinez
    Jan 17, 2007
    3,698
    2,790
    Yeah, I've heard of Einstein's fridge, which I think he co-invented with some other guy to reduce the deaths caused by leaked ammonia used by the old technology. It is my understanding that about the same time that his invention came out, a safe cooling gas alternative was implemented (was it freon?) so his idea never really reached the domestic market. Although it is being used in facilities that require a very high degree of safety against leaks, such as nuclear reactors, I think.
  4. #12
    Nov 30, 2010
    16,704
    7,351
    That is a new method!
    Enabled by the fuel cell technology.
    Not for small stuff like residential, but the large scale method apparently works.
    Einstein didn't have fuel cells.:D
    Anyway, the small scale Einstein cooler works, and it uses ammonia.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Sorry, guys. I edited my original post having reacted mainly to the title. BTW, my first vacuum pump, which was used as a fore-pump for a mercury diffusion pump, was scavenged from a sulfur-dioxide refrigerator. Fun times venting the S02 in LA. I am certain it did not contribute significantly to the smog at that time. Thousands of kids were not doing the same thing.
    John
  6. BR-549
    Sep 22, 2013
    2,181
    419
    I quit reading when it said dry air. No dry air here.
  7. #12
    Nov 30, 2010
    16,704
    7,351
    Here's an old story: My wife phoned me from work and said they were locking down the building and shutting off the air conditioners because of an ammonia leak in some nearby building. My response was, That seems backwards. In a building that size some idiot is going to try to open a window when the A/C stops. Besides, ammonia loves water, and it loves cold water even better. The best way to take ammonia out of the air is to run it across a cold, wet, air conditioner coil.
    Little did I know that my recommendations would be told to, "management" and the air conditioners were back on within 20 minutes.:eek:
    They never sent me a consulting fee.:(
    absf, cmartinez and jpanhalt like this.
  8. #12
    Nov 30, 2010
    16,704
    7,351
    Thanks. That quenches my urge to write the book on A/C history and post it here.:D
  9. #12
    Nov 30, 2010
    16,704
    7,351
    Keep reading. This is a method to work with humid air.
  10. #12
    Nov 30, 2010
    16,704
    7,351
    It's all a matter of scale, and the heat used to regenerate the desiccant is scavenged to make electricity. That's the main reason this design works. Drying the desiccant at 600F would be a game stopper if that energy wasn't recovered as electrical power.
  11. GopherT
    Nov 23, 2012
    6,315
    4,039
    That explains a lot. You always seem to stop whenever reality doesn't match your imagination.
    shortbus likes this.
  12. KeepItSimpleStupid
    Mar 4, 2014
    1,278
    224
  13. MrAl
    Distinguished Member
    Jun 17, 2014
    2,561
    516
    Hello there,
    There actually is a relatively new technology for air conditioning. It uses a stream of air to produce a cooler area. The stream of air is directed at an angle to a surface and the stream plus the angle produce the cooling effect. Dont remember what it is called now or exactly why it works but you can probably find it on the web somewhere.
    But that is mainly it, a strong stream of air angled at some surface.
    Of course we also have Peltier devices :)
  14. GopherT
    Nov 23, 2012
    6,315
    4,039
    A bit of research with the aid of Google and I come up with "fan"
    shortbus and #12 like this.
  15. cmartinez
    Jan 17, 2007
    3,698
    2,790
    gee... I thought that technology was called ventilator :p
  16. GopherT
    Nov 23, 2012
    6,315
    4,039
    You probably call a vacuum cleaner an Aspirator, too.
  17. cmartinez
    Jan 17, 2007
    3,698
    2,790
    Actually... I like to call it an Air Sucker ... :p
  18. GopherT
    Nov 23, 2012
    6,315
    4,039
    Now you made me google it to confirm, a slight variation from French.
    aspiradora
  19. cmartinez
    Jan 17, 2007
    3,698
    2,790
    Exactly! ... but sometimes things don't translate well between english and spanish, even when the word shares exactly the same etymology.
    See: embarrassed and embarazo, or cynic and cínico
    GopherT likes this.
  20. GopherT
    Nov 23, 2012
    6,315
    4,039
    Between English and Spanish, sometimes. Between French and Spanish, rarely.
