Here's a relay drive circuit.
What's next is the PWM and input circuit, then the power supply.
Do you want to add in an emergency stop option? Did the original board support this? Normally, the E-stop switch is closed, but when it goes open the relays are both switched off and the motor will stop. In fact, the motor should actually brake, as the terminals are shorted. This is a transistor controlled E-stop, so it doesn't require a high current switch, or additional relays. Also, as it controls the relays, it should still work in case of MOSFET or diode failure.
