a low pass filter analysis (an infinite chain of LCs)
Discussion in 'Homework Help' started by wannalearn, May 31, 2014.
  1. wannalearn
    May 31, 2014
    The question ultimately asks me to calculate the cutoff frqeuency but at this point, Im just trying to figure out how to calculate the total impedance of the LC network.
    The solution says Znet = Zl + (Zc * Znet)/(Zc + Znet) = Znet
    Based on the diagram, i would have thought it is (Zl + Znet) and Zc that are in series. So, I wouldve thought the solution must be the following: Znet = (1/(Znet+Zl) + 1/Zc) ^(-1)
    Im trying to analyze the given circuit (LC network) the same way I would analyze the following circuit : http://i.stack.imgur.com/n1eIX.jpg
    Rnet = r + (1/r + 1/Rnet) ^(-1) and solve for Rnet.
  2. shteii01
    Feb 19, 2010
    3,501
    511
    I can figure out what Zl and Zc represent.
    What does Znet represent?
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    Znet is the impedance of the whole network.
    The key to analyzing this circuit is to note that, because it is an infinite chain, you can cut it off before any capacitor and the impedance looking into the rest of it will be unchanged. Hence, you can reduce it to a single cap and a single inductor that is connected to a network have an impedance of Znet.
  4. wannalearn
    May 31, 2014
    Thank you for the replies.
    I do understand the point of this being that you can cut it off and say the rest of the system still has the same net impedance.
    The trouble i have is what elements are in series and parallel
    Could you help me figure out what are in series and parallel?
  5. wannalearn
    May 31, 2014
    I hope this clarifies what I have misunderstood.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    You are correct. The given solution makes no sense.
    Note that you have a typo in your original post that made it appear that you were doing it wrong to since you said that (Zl+Znet) and Zc are in series. I think you meant to say parallel.
