A little light project
Discussion in 'The Projects Forum' started by sikter, Feb 14, 2012.
  1. sikter
    Jan 25, 2012
    23
    I would like to make a circuit which consists of:
    -one light bulb (or LED)
    -one momentary switch,
    -power supply ( anything from 1,5 to 12V DC)
    -anything else I need to do following
    When I push my momentary switch the light would go ON.
    Next time I push it, the light would go OFF.
    thanks
  2. R!f@@
    Apr 2, 2009
    8,789
    771
    Momentary has only one state.
    U need a single throw or a push button switch.
    So what else do you need to complete ur light project, a diagram ?
    sikter likes this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have a simple 555 project that does this.
    The 555 Projects
    555 Bistable Multivibrator
    Don't worry about the two LEDs, just remove one of them. It is to show when the chip is high or low, digitally speaking. This circuit would also work with light bulbs.
    sikter likes this.
  4. sikter
    Jan 25, 2012
    23
    Yes, maybe diagram with explanation...
    (But remember this project doesn't include a latching switch)
  5. mcasale
    Member
    Jul 18, 2011
    210
    12
    Sounds like a JK flip-flop would do it.
  6. djsfantasi
    Apr 11, 2010
    2,905
    878
    ...or a mechanically latching momentary pushbutton switch?
    Oops - just noticed latching switches were a no-no
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    I suspect something like the circuit I showed is used for a lot of applications. It used a momentary contact switch, and is fairly simple.
    I also suspect we won't hear from the OP again. Time will tell.
  8. sikter
    Jan 25, 2012
    23
    I just want to thank you again!
    Your links really helped me a lot! That was
    what I was looking for. Still reading the other stuff.
    Sikter
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Naw, but I would like feedback when you are finished. It is too easy to make assumptions when you've done it for decades, it doesn't hurt to get fresh input now and again.
  10. sikter
    Jan 25, 2012
    23
    Hello Mr Marsden,
    I found this video on youtube! It looks very simple but I am afraid that I didn't understand everything the guy said.
    http://www.youtube.com/watch?v=g870KeaHtEQ
    Please comment!
    sikter
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    Forget what he said, look at what he did. This was a simple push button circuit. The LED lights when he pushed the button, goes dark when the button is released. Very basic circuit.
    It is +5VDC, resistor, LED, button. Extremely simple.
    He is using a laptop USB for 5VDC.
  12. sikter
    Jan 25, 2012
    23
    Ok I see,
    Waste of time, actually.
    I saw a lot of videos what includes relays (which I really want to avoid)
    555s seam to be most simple solutions.
    Many people have mentioned a flip-flop solution but I couldn't find out how they worked.
    Would you mind?
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    Did you notice the theory of operation on the bottom link article? If there are part of it that are not clear please ask the specifics.
    This is not your normal flip flop. Matter of fact, it is extremely round about, using the dead space between the hysteretic gates set points. It is unusual to say the least, but it works.
    Most flip flops use inverting gates of some sort, that is more the norm.
    sikter likes this.
  14. sikter
    Jan 25, 2012
    23
  15. Wendy
    Mar 24, 2008
    20,772
    2,540
    It looks like it would work.
    Side note, you were looking at a buck puck lighting the LED. These devices are not pololu switches, which is the simple toggle similar to the 555 circuit I showed.
    Google buck puck. They are neat devices. If you have a 9V battery (say, 3X LM1131 celles) and the LED needs 3.6V at 700ma the 9V source will provide 290ma. This is because they are converters. They are also not cheap, nor is the power LED (3W).
