a little help would do...
Discussion in 'General Electronics Chat' started by mashujin44, Feb 29, 2008.
Thread Status:
Not open for further replies.
  1. mashujin44
    Feb 28, 2008
    6
    Hi, im new here. Just visited this site and i found it amazing that people here help others eventhough the projects are for academics. I would like to ask for help for my elevator simulation project. the elevator is suppose to run by using a stepper motor. yet, as the cart reaches the floor you have pressed, the door must simultaneously open up, like a real elevator. The one that i will be building is needed to be 4-storey, no weighs will be applied to the cart, only the cart itself will be carried up and down. I have read the other posts here, and it says you would be needing limit switches, other says use optical sensors. I have merely no idea where to start from, can anybody help me...
    a link below is the animation i have made on how the elevator should behave.
    http://www.mytoons.com/animation/play/12972
    Note: no programmable logics may be applied.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
Thread Status:
