A little help here: Need Wall Wart + Mating Connector
Discussion in 'General Electronics Chat' started by joeyd999, Aug 2, 2014.
  1. joeyd999
    Thread Starter AAC Fanatic!
    Jun 6, 2011
    2,757
    2,937
    I've spent the last day or so looking for a switched-mode wall wart (or desktop) power supply and mating connector with off-the-shelf availability with the following specs:
    Power Supply:
    Input: Either USA 115VAC 60Hz or Universal 90V - 230VAC 50/60 Hz
    Output: 12V @ 2 to 3 Amps DC
    Output Connector: preferably 2.1mm x 5.5mm female barrel plug, straight or RA, preferably positive tip.
    Connector:
    Bulkhead mounted male barrel jack with rear nut, compatible with power supply connector, 12V @ 2A.
    Here is an example of an acceptable supply:
    http://www.digikey.com/product-detail/en/EPSA120200U-P5P-SZ/T1071-P5P-ND/2235263
    This would work fine, but I cannot find the mating barrel jack rated at 2A.
    Here's an example of the jack, but this one is rated only 1A:
    http://www.digikey.com/product-detail/en/4840.2210/4840.2210-ND/1731061
    So, either I need a compatible 2A rated barrel jack, or a compatible power supply/jack combination.
    Can anyone help?
  2. AlphaDesign888
    Jul 27, 2014
    189
    10
    Try eBay. I used to have an eBay account until they kicked me off for shaking up peadophiles.
    I even had power seller status too.
  3. joeyd999
    Jun 6, 2011
    2,757
    2,937
    Thanks, but ebay is not an option for me. I'd prefer a reputable components distributor.
  4. AlphaDesign888
    Jul 27, 2014
    189
    10
    How about Tayda Electronics then? They're tops.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  6. joeyd999
    Jun 6, 2011
    2,757
    2,937
  7. joeyd999
    Jun 6, 2011
    2,757
    2,937
    They don't have what I need.
  8. AlphaDesign888
    Jul 27, 2014
    189
    10
    Try WES Components. The other side of the world to you but thet will have it.
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  10. joeyd999
    Jun 6, 2011
    2,757
    2,937
    Nope. Need rear-side nut. And I like (but it's not absolutely necessary) the clean finish of the example I gave in the original post.
    EDIT: I'll use this if I have to, but it'd be nice to have something similar to the example.
  11. joeyd999
    Jun 6, 2011
    2,757
    2,937
    I know you are trying to help, and I appreciate it. But they do not have what I need.
    And something I didn't say in my OP, I'll need immediate availability and overnight shipping for delivery to South Florida by Tuesday.
    Thanks.
  12. AlphaDesign888
    Jul 27, 2014
    189
    10
    They say that engineering is all about 'compromise'
    Can't you make do with something else?
  13. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Can't you use the one I gave you first?
    You could cut the sleve and use it as a nut.
    Bertus
  14. joeyd999
    Jun 6, 2011
    2,757
    2,937
    I'd rather use the other front-side nut panel mount option you suggested.
    It is difficult for me to believe that there does not exist a 2A rated jack with my specs, especially since the 2.1mm x 5.5mm is such a common connector!
  15. AlphaDesign888
    Jul 27, 2014
    189
    10
    Overnight shipping? You must be wealthy.
    I'm used to waiting an month for some of my parts.
    Gee whiz overnight shipping!
  16. joeyd999
    Jun 6, 2011
    2,757
    2,937
    Ummmm...
    I am not a hobbyist...I am a manufacturer. And I have customers. And those customers expect product. Without product, I don't get paid. Getting paid is sometimes worth the cost of overnight shipping...
  17. AlphaDesign888
    Jul 27, 2014
    189
    10
    Arh yes business is the slightly different equation.
  18. inwo
    Nov 7, 2013
    2,435
    315
  19. KMoffett
    Dec 19, 2007
    2,584
    234
