A little help from someone with schematic knowledge please.
ItsTheFark
Joined Jun 14, 2009
24
SO if i were to make a list of materials needed to make it, it would be:
3x 10k resistors
NE555 chip
7812 chip
3x 0.01uF capacitors
1x 0.02uF capacitor
1x 1000v 6A diode
24V rechargable battery source
Capacitor bank
1x spool of 22 AWG wire
1x IGBT
wire to connect it all together
breadboard
Is that correct?
By the way.. holy <snip>.. i just realised. What connects the set of circuitry with the 24V power source and the 7812 chip to the rest of the circuit?
Wendy
Joined Mar 24, 2008
23,421
You said it, but a picture is worth a thousand words. :D This is one of the few new OP that has given us a schematic without asking, we don't want to discourage that.
ItsTheFark
Joined Jun 14, 2009
24
Uh oh so i did a no-no?
Sorry guys i didnt know i shouldnt post origional schematics.
But can you please answer one more question? What connects the secment of the 7812 chip-circuit with the power source to the rest of the circuit?
bertus
Joined Apr 5, 2008
22,276
It is very good that you gave the schematic.
This way it is much easier to give an answer.
As Bill said "but a picture is worth a thousand words".
Greetings,
Bertus
hgmjr
Joined Jan 28, 2005
9,027
You did not commit a no-no. Bill Marsden was praising you for providing a schematic of the circuit. Many new posters tend to forget to provide a schematic.
hgmjr
ItsTheFark
Joined Jun 14, 2009
24
Yeah sorry i miss-read, i was about to edit that before i saw what you guys posted right there. :confused:
So yeah im trying to build this, I am not sure if you guys can tell its a boost converter. And sadly the custom symbols are throwing me off, I can get all the generic symbols but not the others.
As I am a new poster here, I am also new to the world of circuitry.
Of course my confusion has spread with what yous aid :confused:
I was hacking camera circuits before this to use their circuits but it simply isnt a fast enough charging for the capacitors so i found this.
With the camera circuit i simply put the power source where it said, , soldered two wires to the "Push Button?" i guess you can call it.. the thing that starts the charging, then connected what i wanted to be fueled by the capacitors directly to the opposite end of the capacitor bank and let it rip.
I am not familiar with input and output pins, grounded pins. http://img405.imageshack.us/img405/7061/schematic2.gif
bertus
Joined Apr 5, 2008
22,276
Helle,
Here to the point of the stabelizer:
The points V_switch and V_cap 250VDC seem to come from another schematic.
Without that schematic I do not know the purpose.
Greetings,
Bertus
bertus
Joined Apr 5, 2008
22,276
I have given some comments in the schematic
For the point at L1 : the capacitor will be charged faster when this point is connected to +24 Volts.
Greetings,
Bertus
ItsTheFark
Joined Jun 14, 2009
24
Ugh, i really want to make this but im afraid ill just be wasting my money to have it not work... Obviously i'm either not understanding what your saying, or I am missing a key point...
What type of power source could i possibly use at that +24V point? Obviously not a battery because there is no + and - lead...
Lastly, i got this boost converter schematic off a coil gun site. for simplicity, where would i attach the ends of the coil to on this?
hgmjr
Joined Jan 28, 2005
9,027
You will need to put careful thought into the selection of the Q1. Since the voltage is likely to rise to voltage peaks in excess of the 250 volts indicated, the rated breakdown voltage across the collector and emitter needs to have a safety margin of 50 voltages or more in order to avoid damage to the transistor.
hgmjr
ItsTheFark
Joined Jun 14, 2009
24
I found all of this on anothercoilgunsite.com Please- Any help would be appreciated as i have to go for a bit now. Thank you all very much for attempting to help me.
(anothercoilgunsite.com > Portable > Construction)
EDIT: Ah! Bertus that is VERY helpful! Now lets just assume it would be for a coilgun... where would i attach the two ends of the coil to?
Bertus- thank you so much your help was well... very helpful. If i can get an answer to the above question i will be able to make it!
bertus
Joined Apr 5, 2008
22,276
Sorry I do not know the schematic of a coil gun.
Beware there are high and dangerous voltages involved.
Greetings,
Bertus
