A learning project
Discussion in 'The Projects Forum' started by Printz, Oct 3, 2010.
  1. Printz
    Oct 2, 2010
    31
    Well I tried this once before and because I didn't read the rules thoroughly it got closed. So let me try this again. I want to build a circuit that does this http://www.youtube.com/watch?v=eqId7g7SC10&feature=related but when one lights up it stays lit. There are other functions I want to add later too, but lets see if I can handle this first.
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    Printz likes this.
  3. Printz
    Oct 2, 2010
    31
    Could I use 2 of them in sequence to run 8 rows of 4 LED's? This might work fine, the input voltage is already pulsed.
  4. marshallf3
    Jul 26, 2010
    2,358
    201
    If I recall they actually come with 10 outputs insequence but I don't think they have very high output capabilities at all thus requiring driver transistors for each output leg.
  5. Printz
    Oct 2, 2010
    31
    Each output won't have to drive but 4 LED's. Still to much?
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    The "absolute maximum" sinking output (Iol) is 16mA
    http://webpages.ull.es/users/fexposit/7490.pdf
    You could place 2 LEDs (Vf=1.7v) and a 127Ω resistor in series, and two of these in parallel for each output, for 4 LEDs per output. But, that doesn't solve the light-and-stay-on condition that you want. I'd use a 555 driving a CD4017 Johnson counter, followed by an OR'ing diode matrix, followed by 4 NPN common-emitter LED drivers. This will give you lots of options for different sequences.
    Ken
    Printz likes this.
  7. John P
    Oct 14, 2008
    1,636
    225
    A 74190 wouldn't do what the video shows, and in fact the notes attached to the video explain that the output element is a 74138 demultiplexer. With that, you can get 8 light clusters even though only 4 are shown.
    If you use a 74HC138, the maximum output current per pin would be 25mA, though going that high wouldn't be wise. With 4 lights per cluster, you could still get them pretty bright if they're the high-efficiency type.
    Printz likes this.
  8. Printz
    Oct 2, 2010
    31
    The 555 and 4017 were the way I was leaning to begin with. I wasn't sure it would hold the rows on in sequence.
    I'm trying to control 8 rows of 4 lights, to make two sides. Turning on from the inside to the outside, like blinkers. If I'm going to be programming something, why don't I go ahead and add another function to the array. I just figured wire it differently to do this one but maybe it might be easier to digitize it. I'm trying to get the 2 array's to operate as one to create brake and running light on my bike.... that has a 2 stroke bolted to the frame.
    I hope I'm not breaking the no automotive rule, I didn't mean to before so if this still falls under that I'm sorry. It's not required to be plated or registered and I just want to be seen better at night. Thanks again everyone.
  9. KMoffett
    Dec 19, 2007
    2,584
    234
    "I'm trying to control 8 rows of 4 lights, to make two sides." With the 4017 just parallel each set of 4-LEDs-and-1-resistor with another set of 4-LEDs-and-1-resistor. One set of each pair will be on the right, the other on the left. You may have to change the 10K resistors to a lower value (4.7K ?) to drive the extra collector current in each transistor.
    Is the chaser version the running light or the brake light? Is the other mode to be just steady, no flashing?
    Ken
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Printz likes this.
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We will let this one go, as the intent is to enhance safety. The OP should use care in construction and mounting, not to mention weatherproofing all connection.
  12. marshallf3
    Jul 26, 2010
    2,358
    201
    I've seen those little weedeater engines that can be clamped to a bike frame and run against the wheel, you can often pedal faster. :)
  13. Printz
    Oct 2, 2010
    31
    The steady will be the running light, which gets brighter for the brake. The chaser is the blinker. I had a little doubt that I'd be able to pull this off. My electronics background is only repairing radar units as old as me.
    I plan on putting the electronics in a sealed box, heat shrinking the wires so it looks clean too. As a future Mechanical Engineer, that's what I'm studying in school, I will make sure to be careful. Thanks.
    Mitchell
  14. KMoffett
    Dec 19, 2007
    2,584
    234
    So the chaser is the left/right turn-signal?
    Ken
  15. Printz
    Oct 2, 2010
    31
    Correct sir. I'll try and draw a picture if it will help, but knowing my art it won't do any good.
  16. tom66
    May 9, 2009
    2,613
    214
    I think turn signals are not allowed to be sequential in some places.
    Wikipedia (http://en.wikipedia.org/wiki/Turn_signal#Turn_signals):
    However, as it says the Mustang has them so maybe there are some exceptions.
  17. Printz
    Oct 2, 2010
    31
    Not to sound like a smart-a$$ but this thing already is a rolling gray area, so adding the signals is the last of my worries. I'm just super excited to have a brake light and BRIGHT tail light. Let me do some searching on the laws and see if we can make the running light pulse slightly for better night visibility. I'll make sure about the turn signal laws too.
  18. wayneh
    Sep 9, 2010
    12,368
    3,224
    Well put! Scooters are definitely on the fringe, and in some places this actually favors the scooter rider since the police would rather look the other way than try to figure out which laws are being broken or not. Behave yourself and they'll leave you alone.
  19. Printz
    Oct 2, 2010
    31
    It's worked for me so far, they leave the bike alone. Once I get this figured out on the bike I'm going to make another more polished version and try it on my 50cc scooter which they really hate, since it doesn't have or need plates and it'll still do 50mph. Safety is the name of the game right now though. Thanks again guys!
  20. marshallf3
    Jul 26, 2010
    2,358
    201
    So are the classic Ford Thunderbirds and a few other cars.
    It's all about they don't want people to think you're driving a police car.
