There comes a time and a place when a difficult integration can become an easy one, i.e.
\( F(x) = \int u\ dv = uv - \int v\;du \)
Consider,
\( F(x) = \int\;x^9cos\;ax\;dx\)
You will need to perform integration by parts TEN times in order to reduce the variable "x" and its exponent to a constant. This is (by hand) horrendous computation.
Let's integrate,
\( G(x) = \int\; x^3\;cos\;ax\;dx\)
So,
\( G(x) = \frac{x^3\;sin\;ax}{a} + \frac{(3x^2)\;cos\;ax}{a^2} - \frac{(6x)\;sin\;ax}{a^3} - \frac{(6)cos\;ax}{a^4} + C\)
Can you see the pattern?
The first term is uv, for each term there after, u is differentiated, v is integrated and the result is multiplied by minus 1 for obvious reasons in the integration by parts formula.
Given any product of the form,
\( F(x) = \int\;(a_nx^n + a_{n-1} x^{n-1}+... + a_{0}x^{0})cos\;ax\;dx \)
Where v can be a sine or cosine, can be integrated in less than one minute, provided the exponent is within reason of course.
Let's return to the first example
and now use the method claimed.
You will be able to integrate this (by hand) in less than one minute I assure you.
Consider,
Let's integrate,
So,
