A free sample suprise.
Discussion in 'Off-Topic' started by MaxHeadRoom, Apr 8, 2014.
  1. MaxHeadRoom
    Thread Starter Expert
    Jul 18, 2013
    10,873
    2,529
  2. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    Which one? Neither have a C of O marked on them, but both are very high quality.
    Max.
  3. Zerotolerance
    Member
    Sep 18, 2011
    56
    10
    What's so good about these compared to a normal J-Box? Just curious on why one would use one of these over a normal J-Box (metal or plastic)? It looks like you even have to drill your own knockouts. Only reasoh I could see myself using this is because it is aesthetically pleasing to ones eye for visible installs. Thoughts?
  4. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    This is the published features.
    I guess for surface applications, yes it is also ascetically pleasing.
    Always the oportunist, I could'nt pass up a free-be when offered, the screwdriver was a bonus.
    I will probabally use this one for a project box to house some portable shop project or other.
    Max.
    FEATURES & BENEFITS
    Hand-close Fasteners
    • Close by hand – tool assist to open
    • 100% non-metallic – corrosion resistant material
    • No loose hardware for easy installation
    Integrated Gasket
    • Injection molded gasket permanently fixed to the cover – no installation required
    • Proprietary material provides NEMA 1, 2, 3R, 4, 4X, 6, 6P, 12, 13
    Molded Mounting Feet
    • Molded-in – no loose parts to assemble
    • Located on corners out of the way of conduit connections
    • Flush with the back of the box for close surface mounting
    • Integrated design of mounting feet offers improved strength Smooth Flat Cover
    • No ribs – offers a flat, smooth surface for mounting of devices or labels
    Built-in Gridlines
    • Easy reference for drilling knockouts
    • Makes conduit alignment a snap
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    They're getting their money's worth out of you. :D
    If I send you a free one of my products will you hype it up all over the forums for me? ;)
    (That's a joke. Before any moderators decide to bench us for spamming.)
    DerStrom8 likes this.
  6. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,529
    How do you know I haven't!:p
    Max.
    THE_RB likes this.
  7. Brownout
    Jan 10, 2012
    2,375
    998
    I will, if it works well and solves a relevant problem!
    THE_RB likes this.
  8. Brownout
    Jan 10, 2012
    2,375
    998
    This looks like it could be used outside, whereas a "normal" one can't. I use boxes like this for projects, especially projects I use on my boat, in the cockpit.
    PackratKing likes this.
  9. Moon968
    Apr 14, 2014
    11
    That is wonderful surprise. Thanks.
