A flashdrive based Electronic billboard
Discussion in 'The Projects Forum' started by cutemanuel, Feb 14, 2008.
  1. cutemanuel
    Jul 10, 2007
    Hi house,
    please im still stucked on this project, trying to make an electronic billboard that will read in its data from a flashdrive instead of connecting it to a PC via the COM PORT, if it is possible, how do i go about it?
    2) If the above is not possible , how do i use the USB PORT instead of the COM PORT to stream in data.
    Manuel
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If it's going to use a flash drive, then USB will have to be the choice. Does the display have a processor in it that can use the USB interface, import files, and display them?
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Reading USB can be expensive, there's a hack to allow simple GPIO to read an SD card in SPI mode. It just so happens that an SD card can fit in a floppy disk connector. Just hook up the right pins and something as lowly as an arduino can play with them. (atmega168)
    http://uanr.com/sdfloppy/
    Tada!
