A decoder question
Discussion in 'General Electronics Chat' started by tt1234, Nov 26, 2008.
  1. tt1234
    Nov 26, 2008
    I wonder is there a decoder avalible for the following function? If not what is the simplest way to build one?
    Input: 0 0 0 0 Output: 0 0 0.....................0
    Input: 0 0 0 1 Output: 1 0 0.....................0
    Input: 0 0 1 0 Output: 1 1 0.....................0
    Input: 0 0 1 1 Output: 1 1 1.....................0
    Input: 1 1 1 1 Output: 1 1 1.....................1
    Thanks for help!
    Regards,
    Tom
  2. leftyretro
    Nov 25, 2008
    394
    No standard off the shelf logic chip would do that function. These days the simplest solution would be to program a microprocessor to perform this decoding, you would need to have enough I/O pins (20 in this case) but it would be a easily implemented.
  3. steveb
    Jul 3, 2008
    2,433
    469
    A programmable logic device works well for this too. (Note, only 19 pins, 4-in and 15-out are needed)
    Also, a standard decoder (for example 74159) could be combined with some or-gates.
    Or, you can work out a solution with only gates.
  4. PRS
    Aug 24, 2008
    989
    35
    You can make your own decoder using 16 four-input Nand gates and some inverters. If you have a TTL data book it will show you the 74154 design (four-input, 16-output) design, but you'd have to rewire it for your purpose. Good luck!
